Anyone install a radar detector yet in a Cab?
Old May 26, 2010 | 10:22 AM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
Anyone install a radar detector yet in a Cab? Is there a 12v socket in the passenger footwell like many other cars?
Old May 26, 2010 | 04:13 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
There is a 12v socket in the glove box and in the center console ashtray.
The glovebox also has a small removable plug that allows you to run a wire from the glovebox into the side access panel (between the dash and the door) - perfect for running power up the A-Pillar to your radar detector.
Old May 26, 2010 | 08:35 PM
Pennetta's Avatar
That's what I was looking for,
thanks
Old Dec 5, 2010 | 02:28 AM
Coonsa's Avatar
E550 Coupe, W465 G63
*bump*
If anyone has hardwired a radar detector in the coupe or convertible could you please share your experience, tips, technique, and possibly some photos.
Thank you.
Adam
Old Dec 5, 2010 | 07:45 AM
Pennetta's Avatar
Yes I did one from the top of the windshield on the drivers side to the glovebox connector, so you don't need to splice anything. Run a straight wire with the male 12v socket on one end and the radar connector on the other. Ran the wire through the rearview mirror/reading lights casing and then continued across the passenger side between the top of the windshield glass and headliner over to the passenger A-pillar(it's loose in here so I wrapped the cord with the small sized spiral plastic wire wrap to add thickness). Then across the rear face of the A-pillar and under the outside weather stripping that is between the pass side window and the A-pillar down to where you are even with the bottom of the glass on the window. Then back across towards the interior of the car to behind the glove box.
My wire was a little wider so that's why I routed it this way. The 12v in the glove box goes on and off with the ignition key too.
It's always better to mount the radar detector as high as possible for a cleaner field of view to the horizon.
Old Dec 8, 2010 | 09:48 PM
Coonsa's Avatar
Thank you for being so prompt in your response. I will be installing one in my coupe over the holidays.
Old Dec 9, 2010 | 09:45 AM
BogeyGolfer's Avatar
11 E550A Cabrio; 13 VW GTI Autob 14 FJ Cruiser, 14 Ural GearUp
How about one that installs in the front grill? Any recommendations?
Old Dec 15, 2010 | 10:34 PM
Coonsa's Avatar
I contacted my dealership about this today. They are getting back to me on the new K40 system, Passport 9500ci, and the Passport Qi45. I will let you know what they say.
Old Dec 21, 2010 | 05:28 PM
lilblaze27's Avatar
C207
Any update from this?
Old Dec 24, 2010 | 08:27 PM
Coonsa's Avatar
The dealership said they have installed the new k40 system in quite a few W212 sedans but no coupes.
