Anyone using a K&N air filter?
hi guys,
i have a e550 coupe and was wondering if anyone has installed the K&N air filters for this car. i had them in my CLK500 and they improved performance and gas mileage. i also tried them out in a GL450 with horrendous results. The response was improved, but the gas mileage went down by 2MPG. and before you comment, no i wasnt stepping on it. i measured it on a long distance trip. so just checking to see if folk are using these and what the results are. thanks in advance for reading and responding.
al
al
2010 e350 coupe
I am using 2 of them in the e350. After a 5000 mile trip I scored incredibly high gas mileage and have been getting great mileage since. I posted an article on the changing of them as I believe the e550 uses a similar dual air cleaner set up to the e350. I think they are well worth the effort and money.
i have K&Ns on my w203 and my w204 and i swear by them. improved gas mileage, improved performance, and i have K&N cones on my w204 with heat shields and the sound from the engine bay is NICE. its a nice purr and then a growl when you step on it. even if you dont go with cones, and just go for the K&N drop ins, still 10000000% worth every single penny. every car i own and will ever own will get K&N drop in filters.
2010 e350 coupe
C300 Sport/Palladium Silver on Black/P2
Yes, the paper OEM filters should always stop more debris from getting into engine.
Furthermore, while it may be a myth, I've heard just too many concerns about the oiled filters. It's not worth the 1 or 2 HP IMHO.
Instead, I just change the OEM filters on a more regular basis than recommend, to not have the bugs and debris that collect, obstructing the airflow.
W177 A250AMG 2019, W212 FL E250 with 63 kit, R8
I agree with 911.
on my E60 BMW 5 series, the pick up was faster using a K+N panel,
and power was up maybe 2%, sounded throatier but
the car was more thirsty (i had a sport exhaust set-up) and the oil was black.
of course these K+N sports filters have bigger holes and more debris, and i threw it away when it was dirty and bought another one, because the oil that they use (re-oiling) messes up the mas (mass air sensor) which=rough idle, so the million mile thing is a gimmick
in the end i changed the oem every season and saved some hassle as oil and oil filter changes are expensive!!!
with the Drum type K+N, the power and sound is up even more, and if u
can handle changing engine oil and filter often it is well worth it!
One guy with a Gruppe M carbon induction kit - it sounded awesome, like a turbine and vacuum cleaner on full blast!!
2010 e550 coupe , 2010 ML550
ive had mine on for 6month and had the ecu tunned aswell. adding the filters gained 5hp and the sound from the engine is just beautiful.
yes i find oil gets darker faster but oh well. besides i push it to the limit every time i drive it so k&n or not oil will get dark
but i recommend it just for the sounddddd
E550 Coupe
Is it possible that you could provide us with a sound byte?
Ive had my E550 coupe for abour 2 months now, got the k & n filters in yesterday and they sound amazing, also removed the resonator and rear cats and replaced them with a custom x-pipe and tuned the engine, i think I get 50-60 more hp so worth it
I paid 600 for the k & n intakes and the tune program, and 500 for the x-pipe and installation. Sounds very aggressive and untamed getting used to it and liking it more as i drive it
I raced most of my life both cars and motorcycles and the only way to tell is to dyno before and after a modification. The other way is to buy something that was specifically designed and dyno'd by a reputable tuner for your model car and engine. On my BMW 535i I did the Dinan stage II ECU mapping and they put in a oiled air filter and they saw no improvement. If you decreased the exhaust back pressure then the oiled air filter helped.
