E coupe 2012 rough shifting
but i noticed rough shifting from second gear to third and first to second in e mode . Im wondring guys do notice that ? plus when i put car on reverse sometimes i hear carcking sound or something like that. Trrrrrtrrrrrrtrr . Sorry if my english not that good
I had to do that a few weeks after I got mine so worth a try.
Additional comments:
There can be a learning curve with a brand new Benz with these trans. They are "adaptive" and will change shifting characteristics after they "see" what your driving style is.
I found that to be true with mine, placed in service August 1. At first, it was a little bumpy in E mode, but it smoothed out beautifully with some miles.
I don't drive much in Sport mode, so it's still a bit bumpier than E mode. Also, I think you'll normally feel shifts more in S mode, since the gear shift points and times held in gears are designed for increased performance.
Nevertheless, cracking sounds are never good and the observations you report here should definitely be checked out by the dealer, per Nab's and Mikey08's comments.
Please let us know the results after dealer visit.
btw my 5speed hasnt been the best so far, sometimes when i decelerate gently for the red light it might downshift suddenly at the wrong time causing the car to jerk( the same effect as it i stomp the brakes), had it for 5 mths now been to the dealer twice to reset the gearbox software or sth like that, but after a few days of driving after the reset, the problem always comes back occasionally
anyone else have this problem with the 5 speed?
The 2012 models get the 7G Plus on all engines which is on a different level to the old 7G and 5G 'boxes, driven a 250CDI back to back with 5G and 7G+ and it's a totally different car. Drove a W212 Saloon with the 350CDI & 7G+ then went back to my D6 with 7G and the new set up is a lot better but I've been able to adapt my driving style to the set up I'm running and I'm happy with that, I always ask for the newest gearbox software whenever I take my car in anyway.
If you keep having issues with the gearbox jerking in downshifting then keep asking for the new software, if it doesn't fix it and there's no fix for it then see if they will sort you out a new car, it has been done by a few over here.
anyway they would replace a new car for us?? wow didnt know such things are possible haha, well i'll just keep updating whtever new software they have then and hopefully it all works out.
I keep trying to tell drivers of the 7g iteration how much improved the Plus version is and they don't -or don't want to - believe me. Having also driven both, the 2012 is indeed a "totally different car." And, of course, the 302hp D.I. motor helps somewhat too.
It just seems like the 2012 is always ready to instantly deliver significant bursts of power-speed with a small, quick and smooth downshift, now matter what speed range you're in, with only a rare exception or two.
All of this observed in E mode. In S mode, I have had no rare exceptions, period.
