How to remove driver's low beam bulb - E350 coupe
Old Jan 2, 2012 | 03:15 AM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Hi guys,
Just bought a 2011 E350 coupe. My fist mod would be replaced the OEM bulbs to 6000k bulbs and the interior light bulbs to LEDs.
I searched the forums and still could not find the way to remove the driver's low beam bulb and the interior bulbs. What is the bulb type of the low beam? D1S?
Can someone please tell me how to do the bulbs swapping?
Thanks for a million.
Old Jan 2, 2012 | 12:55 PM
Ultraman's Avatar
Originally Posted by emdem
H7's for both hi and lo - you have to remove the front wheel
My vehicle came with factory xenon low beam headlights.
After removing the front wheels, what will be next?
Thanks.
Old Jan 8, 2012 | 11:08 PM
Ultraman's Avatar
Just pickup my vehicle on Saturday .
After a close inspection of the engine bay, I found there was a plastic cover with a turn-knob on the wheel fender liner on each side of the vehicle.
Once you turn the knob 90 degree and pull the plastic cover, you can reach the hand and turn the circular plastic cap and remove the low beam bulbs. Looks straight forward and without any problems. I "believe" the D1S bulbs are held and secured by two metal clips.
The other circular projector light beside the low beam (bi-xenon), I don't see any light bulbs inside. It looks like they are factory led type, therefore, it is impossible to change.
Old Jan 9, 2012 | 08:45 AM
AlnoorK's Avatar
2012 E350 Coupe
Originally Posted by Ultraman
Hi guys,
I also wanted to change the interior bulbs to LED, but I cant find a way to open up the lights. How did you do it?
Old Jan 9, 2012 | 09:20 AM
Ultraman's Avatar
I changed all of them already. Go to W204 forum and find the interior lightings D.I.Y. The e-class is almost the same as the c-class procedures.
Old Jan 9, 2012 | 02:33 PM
AlnoorK's Avatar
2012 E350 Coupe
Thanks a lot! appreciate the help!
Old Oct 1, 2012 | 09:47 AM
kalt's Avatar
Hey Ultraman, did you have to remove the wheels to get to the bulb?
Old Oct 1, 2012 | 10:00 AM
Ultraman's Avatar
Please see thread #3. No need to take off the wheels.
Old Oct 2, 2012 | 10:12 AM
kalt's Avatar
Thanks, i will try that once my new bulbs arrive.
Old Oct 3, 2012 | 04:58 PM
Ultraman's Avatar
What is the model of the OEM bulb? All I know is Osram D1S.
Old Oct 3, 2012 | 06:09 PM
kalt's Avatar
My factory bulbs were Osram 66140, i swapped them with the 5000k Osram 66140CBI bulbs.
Old Oct 3, 2012 | 07:28 PM
Ultraman's Avatar
These are good stuff but $$$. How much did you pay for a pair?
Old Oct 3, 2012 | 07:52 PM
kalt's Avatar
I got them from ebay for $132. The seller claims they are new but removed from headlights that got damaged during shipping.
Old Oct 4, 2012 | 12:24 AM
Ultraman's Avatar
Can you do a D.I.Y. with pictures while you are doing this mod?
I believe most of us would like to see.
Thanks.
Old Oct 4, 2012 | 07:01 PM
kalt's Avatar
Thanks.
I will try to put something together this weekend.
