Ideal OFFSET for 20"
Old Feb 10, 2012 | 05:55 PM
sLiQ_e5c's Avatar
E550 Coupe
Ah i seee, OKi so therefore ive decided to go with 20X8.5 Front ET32 (235-35-20) 20x10 Rear ET45 (265-30-20) =)
Only reason i thought id be able to go with 275 in the rear was i figured since id be putting a higher offset than originally planned
Old Feb 13, 2012 | 03:32 PM
joskami's Avatar
S212 350cdi-4-matic `11 "AMG" // C207 350cdi ´10 "AMG"
Now i found wheels what i want, but..
front 9x20 et 40 245/35R20 and rear 9x20 et40 275/30R20.
Maybe front wheels is too wide and that coming too much inside 8mm (0.3") vs orinal setup
Is that too close shock/spring?
Rear i can put 10mm spacer if i liket it.
what you think front wheels?
Old Feb 15, 2012 | 06:17 PM
sLiQ_e5c's Avatar
E550 Coupe
welll i just spoke to giovanna and apparently they are claiming their wheels will not fit my car! They say i need a much higher offset in which they do not offer and will not make custom. The offsets they carry are 20, 25, 32, 38, and 45. I was hoping to get 20x8.5 ET 32 and 20x10 et 45 but they say will not do. -_____- wth?
Old Feb 15, 2012 | 06:32 PM
bigigg's Avatar
14' CLS550
Get them, those offsets will work.. Very flush!
Old Feb 15, 2012 | 08:22 PM
sLiQ_e5c's Avatar
E550 Coupe
i have no clue what to do anymore, i went to 3 wheel shops and their saying it wont fit, supposedly just because the wheel size and offest are the same, dosent mean those will work, one place said every wheel has different characteristics.. never thought this would be so complicated
Old Feb 15, 2012 | 09:20 PM
sLiQ_e5c's Avatar
E550 Coupe
does anyone know if the fact that the gfg f2 is concave has anything to do with the problem?
Old Feb 16, 2012 | 08:10 AM
  #32
threeMBs's Avatar
Only MBs - the best or nothing
They will fit. Flush fitment. No questions about it.
Old Feb 16, 2012 | 08:17 AM
  #33
threeMBs's Avatar
That is absolutely true, but only when dealing with "stock" offsets - a little higher or a little lower. This is where the design of the wheel on the inside will come in play as far as clearance issues.
The offsets you want are much lower than stock. ANY wheel in the offset(s) we discussed above will fit producing a flush fitment.
Old Feb 16, 2012 | 09:24 AM
  #34
joskami's Avatar
Can someone confirm, can i put front 9x20" et40 and 245/35/20"?
Old Feb 16, 2012 | 09:33 AM
  #35
threeMBs's Avatar
If you would read the whole thread you would know the answer - while wheel will fit, tire WILL NOT. All that was specifically addressed above.
Old Feb 16, 2012 | 09:35 AM
  #36
bigigg's Avatar
14' CLS550
Is the lug pattern 5x112? I don't understand why they are saying it won't fit.. Center bore maybe? If there reason is bc of the offset, then they clearly don't know what there talking about.
Old Feb 16, 2012 | 09:38 AM
  #37
joskami's Avatar
Thank you..
Old Feb 16, 2012 | 10:40 AM
  #38
sLiQ_e5c's Avatar
E550 Coupe
I guess im just gna call back and ask if its a center bore issue, which they clearly only stated its a offset issue...
Old Feb 29, 2012 | 01:18 AM
  #39
Jamaicanbro's Avatar
2010 E550 Coupe
Offset for 20x 10.5
What offsets would produce flush with this size in the rear? Fronts are 20x9 so et 42. Tires are 245.30.20 and 275.30.20. Lexani cvx44 wheels. Thanks.
Old Feb 29, 2012 | 01:21 AM
  #40
2010 E550 Coupe
Offset for 20x 10.5
What offsets would produce flush with 20x10.5 in the rear? Fronts are 20x9 so et 42. Tires are 245.30.20 and 275.30.20. Lexani cvx44 wheels. Thanks.
Old Mar 1, 2012 | 08:28 AM
  #41
sLiQ_e5c's Avatar
E550 Coupe
wow 10.5 seems a bit too much to be flush on the coupes,
Hey threeMbs, i was thinking instead of 265 30 20 ET45, tryin 275 30 et 42. what you think about that?
Old Mar 1, 2012 | 09:18 AM
  #42
Dueclaws's Avatar
'12 E550C, Sierra Denali
[QUOTE=sLiQ_e5c;5081028]wow 10.5 seems a bit too much to be flush on the coupesQUOTE]
+1 I've never heard of using 10.5 on an E Coupe, but would be interested in any information that states this is possible.
Old Mar 1, 2012 | 10:18 AM
  #43
threeMBs's Avatar
20x10 et42 will be fine, but I doubt 275/30-20 tire will fit E coupe without rubbing.
Old Mar 1, 2012 | 11:09 AM
  #44
bigigg's Avatar
14' CLS550
If your looking to run 9x20 I'd run a 245/30 not 35..
Old Mar 1, 2012 | 02:44 PM
  #45
gavrocool's Avatar
e350 coupe
I don't know why you are not rying 285/25 same as me?They look great on a 10 width wheel.Nevermind,just my set up.
Old Mar 1, 2012 | 05:53 PM
  #46
sLiQ_e5c's Avatar
E550 Coupe
well because im not planning on lowering my carr, 285 25 tires would look just way too thin
Old Mar 2, 2012 | 05:47 AM
  #47
sLiQ_e5c's Avatar
E550 Coupe
hmmmmm hoping it shouldnt be a problem, prolly do et45 wit 275 n wish for the best
Old Mar 3, 2012 | 08:43 PM
  #48
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Ok so the set up im looking at is the cv3 in 20.. They only make 20x9 et and 20x 10.5
with a 42 at this time... ive done a ton of research but was look for opinions here..
i think with a 245 30 or a 235 30 the front will be fine ... and in the rear a 265 30 or a 275 25 would work...... it will be lowered slightly and i never have anyone in the rear and i do have a fender roller that i would mind using.... it is a 350 coupe
Old Mar 14, 2012 | 12:49 AM
  #49
sLiQ_e5c's Avatar
E550 Coupe
Hey threeMBs, Srrry again but this company is getting on my last nerves.
They first claimed 20x8.5 et 32 and 20x10 et 45.
After a long order process, they are now claiming they dont carry that, instead its 35 et front and 40 in the rear. Would these even work??
Old Mar 14, 2012 | 01:51 PM
  #50
threeMBs's Avatar
They will work.
Front - 8.5 et35 - is just about perfect.
Rear - 10 et40 - is going to stick out by upto 5mm (not a big deal though)
