What does the sport button do?
Old Jul 29, 2012 | 10:25 PM
np888's Avatar
2012 E550 Coupe
What does the sport button do in the 550?
Old Jul 30, 2012 | 10:42 AM
Whufc's Avatar
E250 Cabriolet
I believe sport mode lowers the car a small amount and holds it in gear slightly longer?
No idea if that's true, just what i've been told?
Old Jul 30, 2012 | 12:47 PM
threeMBs's Avatar
Only MBs - the best or nothing
"sport" button does not lower car at all.
Instead, it puts transmission into a "sport" mode which means as it says - earlier downshifts, later upshifts and car starts (when standing still) in the first gear instead of second when in "comfort". "Sport" - for more performance, "comfort" - for better fuel economy.
Old Jul 30, 2012 | 02:40 PM
Dueclaws's Avatar
'12 E550C, Sierra Denali
On our '12 E550C, going into Sport mode also stiffens the ride and allows more aggressive cornering.
Use of "M" mode allows the engine to achieve maximum revs (almost redline): then it shifts automatically. Below redline, you must use the paddles to shift.
Old Jul 30, 2012 | 03:29 PM
threeMBs's Avatar
Yes I stand corrected. My 2010 E550 also has the same exact set up as well - the so called "dynamic handling" suspension. I just doubt that any lowering takes place since MB does not explicitly indicate so.
The "official" info states "a sport-tuned Dynamic Handling suspension lets you alter the damping rates, accelerator response and shift points with the touch of a button".
My initial comment above was appropriate for E350's sport (or S/C) button, not OP's E550.
Old Jul 30, 2012 | 06:17 PM
dav461's Avatar
GTR
sport mode just makes car to switch gear later, in order to get more speed out of each gear. but it consumes much more fuel.
Old Jul 31, 2012 | 04:01 PM
Dueclaws's Avatar
In your model it just shifts different, but for the E550 it also adjusts the suspension. I've made comparion trips using sport and the mileage is only slightly worse: if the vehicle is driven moderately....
Old Jul 31, 2012 | 06:58 PM
dav461's Avatar
GTR
probably. as i do not have so "cool" suspension as you do guys, mine is just simple one...
Old Jun 17, 2024 | 12:14 PM
VarunBajaj's Avatar
2012 E550
my car goes into sport automatically after driving 200 mts or so, after it came back from the dealership for a spark plug repair! lol
the car does drive stiff for sure, and I am a pretty relaxed driver, so getting used to sport mode is taking me sometime and now Ive just lost confidence in the car for some reason. Am i being paranoid, or is going to sport mode gonna be a big issue?
