HOLD function on 2012 E350 Coupe?
Old Mar 28, 2013 | 02:37 PM
yoyofather's Avatar
2012 E350 Coupe
Greetings all - I am just wondering if the 2012 E350 Coupe comes with the HOLD function? Not sure if my car has this feature, but if it does, I never get it work on flat road. Maybe I just don't do it right in order to activate this function. Any clue? Thanks!
Old Mar 28, 2013 | 07:28 PM
Caker's Avatar
C207
Works on my 2010, when at a stop I just quickly release break then press it down as far as I can and it turns on. You will see the word HOLD on your cluster display.
Old Mar 28, 2013 | 09:52 PM
J666's Avatar
E
I've only noticed this feature whenever I'm stopped on a hill, and not on a flat road.
Old Mar 28, 2013 | 10:18 PM
yoyofather's Avatar
2012 E350 Coupe
Just figured how it works, and it works on both flat roads and hills. The trick is that you need to come to a full stop, press brake pedal only half way, and then quickly press down to about 8/10.
Old Mar 29, 2013 | 10:47 AM
Caker's Avatar
C207
Old Mar 29, 2013 | 04:06 PM
BenzMan369's Avatar
2012 E350 Coupe
FWIW, I couldn't get the Hold function to work when I first got the car, no matter how I tried to activate it.
I don't know if I learned or if the car learned but now it works 99% of the time on the first try and I don't have to worry about pressing it halfway first or whatever. I just press down firmly until Hold appears in the Multi Function display, as shown in the video, and I'm set.
Seriously, it feels as though the actuating mechanism wore in or
something. The more I tried to use it, the more reliable it became, without consciously changing my technique one bit.
A small but really nice feature. Glad you got yours working.
Old Mar 30, 2013 | 02:34 PM
lex2go's Avatar
2011 E550 Coupe
Never knew the car even have this function. I think I should read through the owner's manual.
Old Mar 31, 2013 | 11:54 AM
BenzMan369's Avatar
2012 E350 Coupe
HAH! Yes, it may be a good idea to do that! When you do read it, you'll find there are actually two separate holding functions.
The one we've been discussing here is in fact called HOLD. When activated as discussed above it keeps the brakes applied until you step on the accelerator or shift out of Drive, Reverse or Neutral or shift to Park.
The other function is called Hill Assist or Hill Start Assist. When you come to a stop and apply the brakes on a sufficiently inclined surface, then move your foot off the brake pedal to depress the accelerator, this feature automatically continues to apply the brakes for a very brief period - roughly two seconds - to prevent the car's rolling while you get your foot over to the accelerator.
Reading that owner's manual in all it's typically **** Mercedes detail can be a pain, but there's lots of good info in there.
Happy reading!
