2010 E350 Coupe new owner
Old Sep 9, 2013 | 09:56 PM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
updated COMMAND NAV MAPS to 2013 in ~2H
if someone needs latest 2013.2 for E350 get it cheap
ebay 22128083502
Old Sep 9, 2013 | 10:24 PM
uptempo115's Avatar
E550 coupe
Can you provide a link to the buyer you used on ebay?
Old Sep 28, 2013 | 11:27 AM
installed OEM trunk mat from AMG63
direct match and looks very cool
Old Sep 28, 2013 | 11:41 AM
+ salon winter mats
Old Sep 28, 2013 | 12:01 PM
Iowa boy's Avatar
2010 Mercedes E350
New E350
We just bought a 2010 E350 sedan in July. We're still learning about it, but it's some kind of car!
Old Oct 2, 2013 | 02:32 PM
finally after 2 month dealer fixed rear deck noise
90% better now
my dealer doesn't like to share much to customer
customer states there are rear deck rattles
removed seat cushion , rear deck shelf
installed felt type under rear deck
wanted dealer update COMMAND software
Customer stats there are updates available
Found updates for media interface ,sound system and sat radio
Installed updates
still pick up is suck , told him to update DME / ECU , nothing done
Any software update for 2010 3.5L for better pick up ??
Old Oct 13, 2013 | 04:56 PM
  #32
whats up folks
after COMMAND update my NAV stops to work
get it back to dealer and he said because i installed a new NAV it requires to install another patch
whatever 2 dates later all is working again ... wait i see some changes in NAV
it is more bright and has more 3D options now ... cool
still for the engine he told me nothing can be done to upgrade it so i starts to think about sprint booster
Old Oct 20, 2013 | 05:23 PM
  #33
real spoiler installed
Old Oct 23, 2013 | 12:39 AM
  #34
26k miles
Front noise left side on low speed is killing me , dealer was no help
Local shop did inspection , verdict - front struts / or front upper mounts get loose
Asked dealer again to do inspection , success - dealer is going to replace both front struts under warranty
After this checked Bulletins , i think this is a common issue with these cars
LI32.25-P-051123 FEB11 – 212 without Airmatic (489), 207 without vehicle dynamics (483)
dull thumping noises or metallic rattling from the area of the front axle occurring @ speeds 10-45 mph, modified front struts should be installed.
Old Oct 23, 2013 | 08:09 AM
  #35
Iowa boy's Avatar
2010 Mercedes E350
Thanks for your reply Champlain 777. The MB mechanic had it up on the rack and he and I walked underneath and checked to see is there was anything loose. He even checked to see is there was a vibration that was caused from anything including any of the shields. He shook the struts. They still say everything looks and sounds normal to them. I still hear the noise.
Old Oct 23, 2013 | 08:39 AM
  #36
Iowa boy's Avatar
2010 Mercedes E350
Champlain,777, how would you describe the noise you had that was caused by your struts and strut mounts? Mine is a hollow sound. It doesn't sound metallic to me. The noise does sound like it's in the front left of front center.
Old Oct 23, 2013 | 01:13 PM
  #37
First of all you can feel the problem with a classic suspension check
Took the car up on jacks , lock the steering column and push/pull at 3 and 9 o'clock and felt/heard the wheel move.
If case of any movement it will be probably the tie rod or front trust arm bushings ( not our case on 25k miles )
Then do the same at 6 and 12 o'clock
In our case the movement will be at 12 o'clock ( the upper part of wheel )
My Indy pushed the wheel at 12 o'clock when i touched the upper front strut and i can feel that something loose inside the upper strut on a front left driver side , 2-3 MM
Even with car on the ground sometimes I can feel movement at 12 o'clock but this one is tricky and depends of load on front suspension
Second when you drive you mostly feel kind of cracking noise ( kxe kxe kxe ) when car is cold and when you turn the steering wheels left/right on a low speed ( 10-45 MPH )
Third i can feel very slight steering wheel shimmy ( 70 MPH + )
I know it is not a balancing issue ( did road force balance ) and not an alignment issue( have it done when i bought the car )
and not a bad tires
GL !
Old Oct 27, 2013 | 02:23 AM
  #38
new struts installed by dealer ( they appears to be Sachs )
steering feels much better now but some ghost are still there
next will ask dealer to replace trust arm bushings
Old Nov 8, 2013 | 07:06 PM
  #39
i need some help on a radar detector wireless
done with mount , need a good link how to wire it to the top please ?
Old Nov 8, 2013 | 07:18 PM
  #40
ok i think i found what i need to open overhead light
Old Nov 9, 2013 | 03:06 PM
  #41
done
the beauty of this it switch off / on automatically and i dont need to care about this
just start the car ...
Old Nov 9, 2013 | 04:56 PM
  #42
BenzMan369's Avatar
2012 E350 Coupe
90% better now
Installed updates
Any software update for 2010 3.5L for better pick up ??[
Check out this thread from the W212 Forum, among others:
https://mbworld.org/forums/search.php?searchid=12827298
You can also do a search of that Forum for "PCM Reset." I have not done it with my car, but others there who have done it swear they feel an immediate improvement. It's a procedure you can do yourself, if it's right for your model and engine. It basically causes the Adaptive Transmission to "unlearn" previous driving behavior and resets it to original parameters.
I assume you have also tried driving in Sport mode rather than the default Economy mode and you're still not happy with performance.
Old Nov 9, 2013 | 06:37 PM
  #43
ya i tried it
not much difference , i am going for Eurocharged E350 ECU Flash soon
Old Nov 15, 2013 | 02:39 AM
  #44
good news
finally after 2 attempts ( first failed aka no leaking no new bushings ) dealer installed new trust arm bushing ( aka Hydromounts )
wow date and night difference on a WH
still had small wheels movement at 6 & 12 o'clock , appears to be front bearings loose, mostly driver side
dealer told front bearings are not adjustable , what a bul**t
Was follow this guy procedure how to adjust them , - this totally fixed it !!
http://www.benzworld.org/forums/5572226-post18.html
car feels like a new now , finally my suspension saga is over and i am happy camper again
here is the list of fixes on my front suspension
Shock absorbers 2 204-323-30-00 waranty
Dust cap 2 204-323-04-38 waranty
Hydromount 2 204-333-11-14 waranty
Elastomeric cap 4 211-333-06-97 waranty
Bront bearing adjustment both sides DIY
Hood mounts lubed DIY
Enjoy !
Old Nov 16, 2013 | 01:43 PM
  #45
Iowa boy's Avatar
2010 Mercedes E350
How would you describe the noise you had? Was is a metallic sound or something different.
Old Nov 16, 2013 | 03:17 PM
  #46
most noises were when y turn wheels right left on a low speed
it was sound like a cracking/clicking noise
Old Nov 16, 2013 | 07:34 PM
  #47
Iowa boy's Avatar
2010 Mercedes E350
Ok, mine is when I'm driving. Doesn't sound like the same sound. I spent the afternoon in the garage looking to tighten anything that looked like it could make a noise. I was sure it was a tire noise until MB mechanic switched out the tires and wheels from his own E350 with mine and I still heard the noise, so I know what it isn't I just don't know what it is. Seems like I'm the only one who can hear it. Just like the voices...
Old Nov 16, 2013 | 08:57 PM
  #48
trust me even if you know what is the reason it is not easy to get it fixed by dealer
"Seems like I'm the only one who can hear it." ,- in 99% dealer will said it is normal
GL !
Old Dec 5, 2013 | 10:37 PM
  #49
SprintBooster installed
well this little toy indeed makes my MB life much more interesting , finally i feel that this car has 270 ponies even with a green button
nice pick up
Old Dec 6, 2013 | 12:30 AM
  #50
uptempo115's Avatar
E550 coupe
Nice clean install on the radar. Great job!
