Wheel spacers?
Old Oct 21, 2013 | 09:59 PM
Barca93's Avatar
C63 S Cab, Previous Maserati Granturismo Sport and E550 Cab
Wheel spacers?
Anyone use wheel spacers with the stock AMG 18 inch rims for the e coupe? Trying to find which MM spacers to use for front and back. Which size spacers will make the wheels look flush?
Old Oct 22, 2013 | 01:03 PM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
sure
https://mbworld.org/forums/e-class-c...new-owner.html
the only problem with them is a dust which car collects very quickly so if i can get some SPLASH GUARD mmm
I used 10 MM spacers all around( even front calculcation gives me 5 MM ) for a flush look on OE AMG 18" wheels ,
you can get them from ECS tuning and you will need longer bolts
Old Oct 22, 2013 | 02:33 PM
Barca93's Avatar
Ok I will try out the 10mm! Thanks for the reply
Old Oct 22, 2013 | 04:29 PM
Draz's Avatar
2012 MB E350 Coupe
I've used 10mm front and 12mm in the rear.
Old Oct 22, 2013 | 08:45 PM
Barca93's Avatar
I'm in between going 10mm front & rear , or 12mm front & rear
Old Oct 30, 2013 | 08:13 PM
Barca93's Avatar
Ended up going with 12mm front and 15mm rear spacers (H&R). Since my car is lowered I figured it was better to use a more aggressive setup. Will give an update after I get them installed next week.
Old Nov 7, 2013 | 11:47 AM
Barca93's Avatar
Wheel spacers installed! 12mm front and 15mm rear. Please excuse the water marks on the car... http://www.flickr.com/photos/107952108@N03/10727919403/
