RIMS?/TIRES?/Help ASAP PLEASE
Old Mar 3, 2014 | 06:47 AM
jmflamingo's Avatar
2010 Mercedes E550 coupe
Hello members Im an owner of a E550 mercedes coupe, I really love my car but I have no knowledge on rims tires etc My stock tires and rims are like every one on this forum
FRONT WHEELS: 18 X 8.0" OFFSET 45MM. 235/40R18
REAR WHEELS: 18 X 8.5" OFFSET 49MM. 255/35/R18
I want to upgrade to 19' wheels from what I found on this forum I came to the point I know they need to be
FRONT WHEELS: 19 X 8.5" ET ?dont know ?. tire 245/35/19
REAR WHEELS: 19 X 9.5" ET? dont know? tire 275/30/10
My suspension is stock I dont want to change anything on my car what offsets do I need for front and rear ??
Are all the other things fugured out good ? tire size rim width etc ?? will the car look good ? (wider) ?
thank you very much for help
Old Mar 3, 2014 | 08:36 AM
amgboyw204's Avatar
c250 coupe .2012 e550 coupe
Front 35
Rear 45
Old Mar 3, 2014 | 04:19 PM
jmflamingo's Avatar
Originally Posted by amgboyw204
Front 35
Rear 45
https://mbworld.org/forums/e-class-c...550-coupe.html
check out one of the last posts he put 43 all around and it looks very good are you sure 34 in front is ok?
Old Mar 3, 2014 | 05:58 PM
amgboyw204's Avatar
Originally Posted by jmflamingo
https://mbworld.org/forums/e-class-c...550-coupe.html check out one of the last posts he put 43 all around and it looks very good are you sure 34 in front is ok?
34 or 35 in the front will be ok with a
(245 35 19 tire) The pictures show a 34 offset in the front an a 46 offset in the rear but I would do 43 or 45 in the rear for a flush look with a
(275 30 19 tire )
Attached Thumbnails RIMS?/TIRES?/Help ASAP PLEASE-image-3389015732.jpg   RIMS?/TIRES?/Help ASAP PLEASE-image-2597840646.jpg
Old Mar 3, 2014 | 06:03 PM
amgboyw204's Avatar
Old Mar 3, 2014 | 06:04 PM
amgboyw204's Avatar
Old Mar 4, 2014 | 12:18 PM
jmflamingo's Avatar
I got a good deal on a set of rims offset 45 all around , if I put na 10mm spacer on the front it would make my offset 35 is that corect ?
(275 30 19 tire )
Old Mar 4, 2014 | 05:07 PM
amgboyw204's Avatar
Yess it will make the wheel 35 "' post some pics when u get everything install
Old Mar 6, 2014 | 05:25 PM
jmflamingo's Avatar
can I just use ET 35 all around with same tire size ? will that look good ?
Old Mar 6, 2014 | 05:52 PM
GerryMac's Avatar
2012 E550 Coupe
Are the wheel widths the same as you previously posted, 8.5F and 9.5R?? AMGBOY gave you the best advice ... et 35 front with 245 tire and et 45 rear with 275 tire. 35 offset in the rear will poke outside the wheelwell too much and will likely rub.
You could use 245 tires all around but with an E550 the traction on the rear would suck hence the 275 recommendation by AMGBOY
Old Mar 7, 2014 | 03:58 AM
jmflamingo's Avatar
but you see in this link
https://mbworld.org/forums/e-class-c...ed-winter.html
gavrocool is using 35 all around and it works ?
quote
"the winter wheels are 19's,245/35/19 et35 front and 275/30/19 et 35 rear"
Old Mar 8, 2014 | 09:54 AM
jmflamingo's Avatar
anyone ?
Old Mar 14, 2014 | 02:51 PM
nawlinstornado's Avatar
2012 E550 Coupe
I believe he also has a modified suspension.
35 on the rear is going to be close but fine if you're using 275 tires. If you're going 285 (like me) then I'd recommend 45.
I have ET 40 on the front with 255s, and it's fine. But I had the same tires with ET45 and it rubbed the struts. Would have preferred 35 but it wasn't available. Moot, since the 40 works but the 35 would have looked a little more perfect.
Old Mar 16, 2014 | 05:42 AM
jmflamingo's Avatar
Hello guys I just have this one last question for help , Im planning to get my rims tomorrow . I've decided to go with Vossen CV3's I want to put the 19 inch rim( stock suspension) I want to go with
Front 19x8.5 ET 45
Back 19x10 ET 55
(only logical vossen ET for this rim and car)
as for tires
front 255/35-19
Rear 285/30-19
Please i Plan to get this set tomorrow can anyone confirm they will fit ?
Old Jul 1, 2014 | 08:44 PM
venom_55's Avatar
2012 E550 Coupe
Did you get this setup? Any pics? How is the fitment?
Old Apr 21, 2015 | 07:35 PM
seshead's Avatar
E550 Coupe
How is this setup?
19 x 8.5 et 35 with 245 tires
19 x 9.5 et 40 with 275
Think I can squeeze 285 on the back?
Car will be stock. I have no plans on dropping
