H&R Spacers and Lugs Questions
Old May 26, 2014 | 11:33 PM
23wt's Avatar
CLS550 4matic
I had a local shop order 10mm spacers and extended lugs for me. I gave him the info which was 2010 e550 coupe with oem wheels and he ordered from H&R. What I got were 10mm spacers with 35mm bolts. He told me he ordered according to H&R and they said 35mm lugs were correct if using 10mm spacers for the e coupe. Just wanted to know if it was safe to 35mm instead of 37-40mm which most people suggest and are using on the forum. I am 2mm short from what is recommended (27mm+10mm) and getting a little over 5 full turns before torquing. TIA
Old May 27, 2014 | 01:10 PM
uptempo115's Avatar
E550 coupe
These are such a pain to buy without trying. If you get 1mm too long, you could damage the ABS or park brake system in the rear. I'd want a minimum of 7 turns to be safe.
After I lowered the car and added spacers with aftermarket wheels, it took a few tries with different sizes to get it right.
Old May 27, 2014 | 09:07 PM
23wt's Avatar
CLS550 4matic
I understand if the bolts are longer by 1-3mm, it may hit the ebrake in the rear. So maybe that is why H&R didn't send 40mm bolts. Assuming H&R bolts are quality QC items, my concern is 2mm less of bite into the wheel hub will be a huge factor.
uptempo, may I ask what spacer size and bolts are you using?
Old May 27, 2014 | 11:02 PM
uptempo115's Avatar
E550 coupe
I'm running 10mm spacers with 37mm bolts. 40 was too long.
Old May 27, 2014 | 11:31 PM
23wt's Avatar
CLS550 4matic
40mm really too long eh? where did you 37mm bolts? or u machined them down?
Old May 27, 2014 | 11:59 PM
uptempo115's Avatar
E550 coupe
Bolts came from a local shop here called Tunerworks. I'm not sure how thick the HRE rims I got were, so it really could be dependant on your rim.
Old May 31, 2014 | 04:05 PM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
be careful with bolts
based on BMW experience i got conical lug bolts but i was wrong as MB uses rounded lug bolts
All the rest is simple , 1-3 MM does not make any difference
GL
Old Jun 2, 2014 | 04:46 PM
23wt's Avatar
CLS550 4matic
Well my lugs from RAD came in and unfortunately the rear was ticking, but left side only. Took awhile to hand turn the front bolts, don't know if its because they are brand new bolts. Was so tight after 5 turns. The bolts i ordered were 14mm x 1.5mm R14 40mm shank. Seems i really need to shave off the extra MM.
