Anyone has 20's wheels and installed H&R springs?
Old Oct 22, 2014 | 04:16 PM
kellankong's Avatar
MB E350 coupe 2012
I have a set of 20's wheels, and decided to lower my car with H&R springs yesterday. But the result makes me rly down, the drop at front is alright, but the rear is really low, I cant even fit my little finger into the gap and i can barely drive my car from the back of the shop to the front. (its rubbing already)
What can I do if I still want to use the springs? Changing a coilover is not a option to me yet.
Old Oct 23, 2014 | 11:54 AM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
Mine was the same, but has evened out a bit. I wouldn't say it's EVEN, but the front is lower, and therefore seems more in line with the rear. Here are the most recent pictures of it: https://mbworld.org/forums/e-class-c...pe-dipped.html
Those are 20" wheels as well. The rubbing you hear, is most likely the fabric like wheel well liner in there. At least that is what it was for me. I don't hear anything anymore unless I hit a big dip.
Old Oct 23, 2014 | 11:55 AM
zulumerc's Avatar
ECS Supercharged C6 Corvette& 2012 E550 Coupe
i have 20s on h &r what is the offset on the wheels and what size tires are you running?
Old Oct 23, 2014 | 03:06 PM
kellankong's Avatar
MB E350 coupe 2012
Whats ur offset? Did you do alignment for the rear?
Old Oct 23, 2014 | 03:26 PM
kellankong's Avatar
MB E350 coupe 2012
20X8.5 +44
20X10.5 +45 with 10mm spacer
245/30/20
285/30/20
Old Oct 23, 2014 | 05:32 PM
20X8.5 +44
245/30/20
285/30/20
I don't recall my offsets, but I do remember them being in the mid-40s. Though, I'm running 9" wide in front (with 3mm spacer) and 10" wide in back. 10.5" seems like it might be too wide? I'm guessing if you add the spacer, it probably pushes the tire out to where it will rub against fender.
You could just not use the spacer and cut sections of the wheel well lining out if that is what the tire is rubbing against.
I'm not expert on this subject though, just thinking out loud.
Old Oct 24, 2014 | 10:55 AM
zulumerc's Avatar
My specs
20X8.5 ET35 245/30/20
20X10 ET42 275/30/20
Your rims in the back are too wide.
Old Oct 29, 2014 | 01:49 AM
2010_E550's Avatar
2010 E550 Coupe
just remove the spacer and add some camber in the rear. it should fit.
Old Oct 31, 2014 | 01:49 PM
gavrocool's Avatar
e350 coupe
20X8.5 +44
245/30/20
285/30/20
You do not have a correct fitment for the rims as well for the tires!
