Brake pad and rotor replacement (DIY)
I've noticed there instructions for a DIY for the C-class (https://mbworld.org/how-tos/a/merced...-rotors-387311), but was wondering if it would also apply to the E-Class coupe (C207). Specifically, I was looking at replacing the front pads and rotors.
Also, are there any brands/combinations to recommend? (I live in Canada, so my options are quite limited outside of going to the dealer...I was thinking of getting my parts from RockAuto.)
Thanks in advance!
I've found this:
and this:
but am not sure if the process would be the same on the C207.
Any ideas anyone?
In fact I found it easier to do than on my previous BMW's.
Make sure you use penetrating fluid on the single bolt on the disc face as often they can seize and it is also soft metal so you can easily damage the head. Pain in the butt to drill out. Makes sense to replace all of them.
I would also change the anti squeal clips, they are cheap to buy and are often overlooked when doing the brakes. Many don't replace then wonder why their brakes squeal after doing the work.
Which ones are the anti squeal clips that you mention above. Also the procedure of replacing the brakes is the same as the ones shown in the video above? Lastly which brand of brake disk and pads are you using?
Thank you in advance,
Louis
The anti-squeal springs are the standard ones on each wheel again Mercedes original.....
