NEW Facelifting and retrofit project E550 CAB
I am looking at headlights, trying to figure out what to do. My data sheet said I had 'BI_XENON Headlight w/active curvelight'. The 2014+ headlights I have found to use are a non active LED headlight and an active, like so
I wonder if you have ever seen the non active headlight at day or night ? I've seen pictures of the active headlight lit up like yours, but not the non active. I like the active ones, but they are quite expensive. Which headlight would be the easiest for me to make work ? How did you figure it out ? I don't think there are any competent Mercedes garages that can help me, so there will be me and an ohmmeter. Thanks
Very well done Chris... I really like the job and passion you put in this. I actually don't have an E class but when reading the whole post I have a real appetite for buying a retrofit and upgrade it
If this could help you guys, you can but the Hella headlights here:
https://www.oscaro.com/projecteur-pr...-46697-2713-gt
They usually have good prices and service.
cheers
cheers
The corect full led one is about 900 euro each. There is NO H7 bulbs in the full led version.
Will need your advises when I will get the C207 ... Hopefully
