Dynamic handling pack with suspension!
Old Dec 26, 2015 | 04:56 PM
sportlineman's Avatar
E250 COUPE
It's been a long time since my last post. I felt that it's is important to share. I just order a kW dcc suspension for my 2011 e class coupe. It seems that this is the only compatible suspension with cars equipt with dynamic handling / Agility control. I hope this is a solution to the lowering problem with those cars. Anyone who install dcc in his car? Please note that this is not the standard kW v3 with the electronic dumping cancelers.
http://kw-suspensions.be/nl/the-adap...z-automobiles/
Old Dec 26, 2015 | 09:54 PM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
I have an E-Coupe with dynamic sport suspension and am very interested in hearing how this works for you. What is the part number for this kit? Hopefully this is available in the USA.
Old Dec 27, 2015 | 04:36 AM
E250 COUPE
As I know there are 2 models depending on the axel weight of the car.
Try the link below.
http://www.cougar-raceparts.com/prod...ic-dampers.cfm
Old Dec 28, 2015 | 02:19 PM
ffr2014's Avatar
I researched on KW Suspensions website and it looks like all the available Coilover Kits for the E550 Coupe w/ Dynamic Suspension requires disabling of the MB Electronic Damper Control (KW provides the Disable module).
There does not appear to be a KW DDC "Plug & Play" Coilover available for the E550 Coupe.
Try the link below.
Old Dec 29, 2015 | 12:17 PM
E250 COUPE
KW V3 comes with the dynamic handling canceler as optional I guess. kW DCC comes with a central module that connects to my car. According to the KW local dealer.
Old Dec 29, 2015 | 12:35 PM
ffr2014's Avatar
Please post observations when you get this installed on your E-Coupe.
Old Dec 29, 2015 | 03:18 PM
ffr2014's Avatar
I just received confirmation from KW North America that the KW DDC Plug & Play Kit is only available in Europe and only for the MB E350 Coupe (will not work for the E550 Coupe).
Old Dec 30, 2015 | 02:28 PM
E250 COUPE
Mine is not even a 350 it's a 250! I will post something when it's installed. Although I have a problem lowering the car as I installed wider tyres and with my existing rims it's Imposible to go low!
Old Dec 30, 2015 | 04:48 PM
Lethalindustry's Avatar
Brabus
I find it pretty weird that KW DDC is available for every model except E500/E550. I can't think of any other reason except the heavier engine which is weird. It is less than 50kg heavier than E350 CDI and that is a difference betwen full and empty tank.
Old Dec 30, 2015 | 05:14 PM
E250 COUPE
I will ask my kW dealer about that. There were two models available depending on the axel weight so I guess it's something to do with the weight!
Old Jan 27, 2016 | 03:15 PM
ffr2014's Avatar
The other reason is plug and play for the dynamic sport suspension in the E550 Coupe.
Old Feb 3, 2016 | 08:39 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
I'm also looking for the KW DDC for my 2014 E500 but my KW dealer also told me that is available for the E500 beside mine beeing a 2014 version, but I'm not so sure that it will have the plug & play module!
I sent an email to KW almost 1 year ago and got no answer from them!
I might try to call them in Germany when I have some time.
Old Oct 1, 2019 | 04:23 PM
E250 COUPE
Finally installed
Hi all finally after so long I am on KW DDC with 20" inch wheels. Unfortunately I have a few rubbing problems on the rear when I hit a pump. I am planning to widen my rear fenders, has anyone done something similar?
Old Oct 1, 2019 | 04:30 PM
E250 COUPE
Old Oct 3, 2019 | 06:11 PM
wtcnbrwndo4u's Avatar
C207 E550 Coupe
Looks great my dude!
Old Oct 4, 2019 | 07:51 PM
gaiex's Avatar
How is the ride with the KW DDC?
The rear is not to soft almost the same as the stock suspension?
I'm also runing KW DDC on my E500 coupe
Old Oct 6, 2019 | 06:21 AM
E250 COUPE
Maybe I am wrong but I feel that the new suspension is softer than the original especially on the rear. Comparing with KW V3 I still have 2 options as with the original, soft/hard(eco/Sport mode). I was hoping that I could make it stiffer in order to reduce some rubbing in the rear but no luck. Just wident my rear fenders for 5mm each.
Old Oct 7, 2019 | 07:09 AM
gaiex's Avatar
That's why I asked, the rear is way to soft, but I was thinking that could be a E500 coupe related problem, since my car is way heavier that yours.
Beside the soft rear I had a left / rear difference in stiffness also that got the car loose in some situations that I not crashed by luck.
It passed two years that I have the KW DDC, and I had front springs replaced for stiffer ones two times, and rear ones one time, and all 4 coils where sent back to KW germany to be revised and still got that soft rear.
Only one month back I found a work arround that helped a bit but rear is still a bit soft but I got a better handlig and resolved that left/right stiffness difference.
In Xentry on the suspension setup I made a new calibration on the shocks/suspension, that helped.
If I knew that this was the result I would went with the V3.
Old Oct 11, 2019 | 02:38 PM
E250 COUPE
Have tried the ecu module and mobile app? It looks that you can control the suspension in regards of stiffness.
Old Oct 11, 2019 | 02:46 PM
E250 COUPE
Wider rear fenders
Just got the car back from the body shop with wider fenders
Old Oct 11, 2019 | 05:57 PM
gaiex's Avatar
Do you have the ECU module in your car?
KW told that wasn't possible to add !
Old Oct 13, 2019 | 01:31 AM
E250 COUPE
ECU
No I don't have the ecu yet. It was 500 euros extra to purchase. I am not sure I will need to confirm with KW.
Old Oct 13, 2019 | 01:22 PM
gaiex's Avatar
If it was possible to add the KW ECU it would be great and it will solve the problem...
