2010 E550 coupe Help!!! ESC appeared then disappeared, now check engine light on!!!
Old Jul 16, 2016 | 10:50 AM
tdpthagenius's Avatar
MB E550 Coupe
I have a 2010 E550 coupe, and yesterday I was driving from lunch, and there was slightly traffic, standing still every so often, not to mention it was HOT (heat indexes over 105)!!! As I am about to accelerate from the stop light, the ESC light comes on the dash, and I get the message that goes along with it (esp inoperable see manual) and my car wouldn't accelerate over 5 mph. So I coast to the gas station, and park in the shade and turn the car off for 5 minutes. I turn it back on, the message is gone, and it drives just fine. I immediately drive it home, and let it sit until the sun was going down, ran an errand up the street, still no message and car runs fine. I go back home, and about 2 hours later, I go get dinner up the street. Still all good. I pull into my driveway and now the check engine light comes on. Has anyone else had this happen to them? Could the heat be the culprit of all this causing the car to reset itself? The battery was replaced by the previous owner right before he sold the car to me, which was a little under 2 years ago. HELP!!!
Old Jul 16, 2016 | 06:15 PM
MB E550 Coupe
Update...went to O'Reilly and had them run their check engine diagnostic...the guy agreed with meach that it may not pull what it is...but shocked us and it did...gave a p2101 throttle actuator control motor circuit range...Google searche'd and seems this is a $1200 sensor...I'm going to get an official diagnosis on it monday...
Old Jul 16, 2016 | 09:06 PM
bmeck2003's Avatar
2017 E300, 2017 C300
I had the same exact problem with my 2010 E350 coupe. Happened twice a few weeks apart and could barely accelerate. Pulled over, restarted, message disappeared. The third time scared the he-l out of me. I was entering a highway trying to merge into 70mph traffic and pressed hard on the accelerator pedal. The same problem occurred at a critical time. I thought I was going to cause a serious accident.
I quickly swerved to the shoulder of the highway and stopped. After calming down, I restarted the car and drove directly to the dealer. They diagnosed the problem as the accelerator module and replaced the module. Luckily for me my car is still covered under the extended warranty.
Good luck with getting your car repaired.
Old Jul 18, 2016 | 03:57 PM
MB E550 Coupe
I was just told by a mechanic he couldnt tell me what else is wrong with it until he puts new brakes on...lolol ive been doing my research and narrowing it down to the accelerator module...im going with that angle next...
Old Jul 19, 2016 | 12:22 AM
CDM Motorsports's Avatar
Former Vendor of MBWorld
clk and e coupe
Have you checked the codes yet?
Old Jul 19, 2016 | 01:24 PM
MB E550 Coupe
funny thing is i went to pick up the car today, and he reset it all and the check engine light is no longer there...he said his tech drove it around, and the ESC message never appeared either...but as soon as i got about 5 miles out from the shop, the message appeared...my next step is im just gonna replace the pedal and see what happens from there since that seems to be the common solution...
Old Jul 21, 2016 | 10:43 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
Originally Posted by tdpthagenius
I was just told by a mechanic he couldnt tell me what else is wrong with it until he puts new brakes on....
maybe he meant to say BRAINS and not brakes. dont go back to that guy, hes about to rip you off.
Old Jul 22, 2016 | 11:38 AM
MB E550 Coupe
Yea I quickly got my keys and drove it home...he was not about to make $1200 off of me for brakes!!!
Old Jul 23, 2016 | 11:33 AM
MB E550 Coupe
Just an update...replaced the pedal, seemed fine, then took it for a late night test drive, go over a hump in the road and message appears...turned off, turned back on, made a sharp turn, message appeared again with check engine light...
Old Aug 9, 2016 | 02:44 PM
MB E550 Coupe
update...soo throttle body was replaced...drove about 30-40 miles from shop to home...no issues...started heading to work this morning, got on freeway, speeds it about 70, no issues...exited the freeway...no issues...get about 3 miles from the freeway exit i took and check engine light comes on, giving codes p0171 and p0174...im sooo at a lost now as to what to do!!!
Old Aug 9, 2016 | 06:35 PM
beejAMG's Avatar
Try to erase error with OBDIi reader if you have one. And see if it re appear.
More info on your error..
http://www.autocodes.com/p0171_mercedes-benz.html
Old Aug 9, 2016 | 09:16 PM
MB E550 Coupe
As soon as I got home from work I started the car, lifted the hood and heard humming...it was very loud and obvious...I started seeking and about 30 seconds later found what is in the pic below...I'll be ordering more hoses asap...lol
Old Aug 9, 2016 | 10:38 PM
beejAMG's Avatar
Wow, looks like youve got termites! Lol
Never seen that before on any car. Bright side, should be an easy fix.
Old Aug 10, 2016 | 02:31 AM
MB E550 Coupe
This Texas heat has not been generous to these hoses!!! Lol
Old Aug 10, 2016 | 10:04 AM
Late's Avatar
03 SL500(Sold), 09 C300, 11 E550
are you talking about the cracks on the plastic flex portion of the air intake pipe? Deff replace that but... i don't think that would cause your issue
Old Aug 17, 2022 | 09:33 PM
Ulisssesss's Avatar
2010 E550
Fix?
Did fixing the intake tubes fix the check engine light? Or what is it a lost cause?
