Help? Need Part #
Old Oct 7, 2018 | 09:28 AM
erich_aux's Avatar
2012 E350 Cab
Help? Need Part #
Just bought a 2012 E350 cab, and I failed to notice that the little flip cover that goes over the convertible top switch was missing.
Does anyone know if there is a part number for that?
Thank you in advance.
Old Oct 7, 2018 | 11:43 AM
konigstiger's Avatar
'71 Pinto
VIN?
Old Oct 7, 2018 | 11:53 AM
erich_aux's Avatar
2012 E350 Cab
VIN?
Here you go.
WDDKK5KF2CF155173
Old Oct 7, 2018 | 12:33 PM
'71 Pinto
20768000198P08
File Type: pdf
Old Oct 7, 2018 | 03:34 PM
erich_aux's Avatar
2012 E350 Cab
20768000198P08
Thank you, I appreciate your response!
I found that but was not too sure. I think one of the sources I found did not say it would fit 2012, but only 2014-2016.
I think I’ll double-confirm that at my local dealer.
(I hope you do not take offense to that.)
Plus, I do not see mention of a color, so I want to make sure I order the right color.
Old Oct 8, 2018 | 06:29 AM
'71 Pinto
Absolutely, confirm with dealer. EPC capture is VIN specific color code is 207680019 “8P08” almond beige.
Old Oct 17, 2018 | 10:39 PM
erich_aux's Avatar
2012 E350 Cab
Is there any chance there are install instructions for this part #?
I was hoping I could just pop the “cover”piece of this off and pop it on in my car.
Doesn’t look a good idea to try that at all, so I’m going to have to take the center console apart, disconnect the convertible top switch, Yada yada, the. Put it back together.
Alternatively, if there are instructions for replacing the top switch (a2078207410), that would probably be just as helpful and perhaps easier to locate.
Old Oct 18, 2018 | 11:03 AM
'71 Pinto
See if this helps...
File Type: pdf
Old Oct 18, 2018 | 01:51 PM
erich_aux's Avatar
2012 E350 Cab
Thank you, @konigstiger !
I only had a minute to briefly look over the pdf, but I believe it will help.
