M276 2012 E350 coupe startup rattle
It moved hard, took a lot of pressure but it did move. Have to be very careful, it takes so much pressure you can move it too far easily. Once I had moved this pulse wheel into position I reassembled the engine and fired it up. Right away the computer now sees the pulse wheel and the new cam adjuster on the bank 2 driver side intake cam started adjusting as it should. Check engine light is out. Engine now starts instantly, no delayed cranking and no start up rattle.
My thinking is that the failed adjuster and loose timing chain on start up hammers on this camshaft and the vibration makes the cam wheel slip out of position??? I have not heard of any cams being out of position without also having a failed Cam Adjuster or chain rattle at start up? There is no load on the pulse wheel so I suspect my wheel will continue to work properly as long as the Cam Adjuster and chain tensioner work properly with no start up rattle. I hope I am correct this was a 2 hour fix start to finish without removing the Valve cover or front timing cover. Engine runs like a top, quiet and instant start up so it feels like it worked. If my pulse wheel had moved easily I would have gone for a new cam but it was difficult to get to move. I think it is good.
My Scan tool shows all 4 cam adjusters now working and adjusting properly, before this repair the bank 2 intake cam adjuster would not adjust and was stuck in one position. My scan tool told me the cam was out of position and could not function until proper position was achieved. I was thinking I messed up and the timing was 1 tooth off.
Update tonight: Was able to take this car on a 50 mile drive, first 25 miles were mostly uphill with several steep grades, the engine pulled really well, better for sure than before the repair. I had purchased this car broken so I never felt it run at 100%. I set the cruise control at 74 headed up the hills. It held 74 without downshifting running close to 2,000 RPM. I was impressed. Power is very good. I took it to redline twice just to see how it sounded and if that caused any issues. All Good. I think this is a good runner now, it actually sounds like a good Mercedes engine instead of the rattle trap, slow starting beast it was before. I appreciate the tips the forum offered along the way. If the pulse wheel moves on me in the future I will certainly report back. All Good for now and I am happy.
I ordered the cam adjuster timing cover bolts check valve and tensioner, driver side, some tools too.
One thing I'd like to make sure of before getting greasy, and I bet you know having done both sides, Will 40° past TDC give the chain slack to get the tensioner off both sides? Or is it different degrees left to right side?
I just removed and replaced a camshaft yesterday so this is fresh for me. With the cam cover off I rotated the engine by hand as I watched all the valve positions. I was looking to find a spot where the cams were not compressing the valves open. I found what I thought was the best spot, in this spot the timing chain adjuster was also at its most extended position which means when you remove it you will have the most amount of chain slack, on install from this position the tensioner can go back in with no effort at all due to this available slack. This is an eyeball thing, watch the cam lobes and watch the tensioner. My TDC mark on the crankshaft was nearly straight down in this spot I chose to use. Now in this position mark your camshafts. Mark the chain clearly to the exact spot lining up with one tooth on the sprockets, Mark the cams so you know where they line up to the top of the head on each side. This is not a guessing game, timing has to be exact or you will be doing this over again to fix it,. Before you glue down your valve cover test install it and install all bolts carefully to bring the cam all the way into position. With these bolts tight now rotate your engine and verify your timing marks through the windows at the cam position sensor holes. The timing will be off just a little on this side of the engine because the tensioner is not full of oil and pressurized but it will be close to perfect. I am sure I missed some steps. You also need to know that the cams will not fall back into the perfect spot and allow you to bolt it back in. You will be moving the cams a little and the crank a little to get all your marks lined up, just make sure you keep tension on the timing chain so it does not jump timing down low in the engine or you will be out of luck. You can hold it tight with your fingers while you slightly rotate the crankshaft to align on install. I also snap a vice grip tool on the cams to hold them where I want them. There is a spot you can use near the center of the cam that is open and is not a bearing surface to do this. This is a complex job and needs to be perfect or you pay a price so study up and don’t trust my notes, I may have forgot to mention something important.
I'll have the tensioner check valve and the adjuster for the driver side ready to install. I figure if I'm in there best to do everything so I don't have to spend $70 on another set of bolts.
https://youtu.be/dVFfIcrQfus
https://youtu.be/frSl7MZDhB8
I was going to start by removing the driver side timing cover and inspecting the intake adjuster by rotating the engine by hand and seeing if it jumps or pukes oil like so many do when bad.
How do you verify this plate is in the correct position respect to the camshaft w/o taking off the valve covers? I thought the laser marking was in the back.
When the rattle starts, the damage has been done to the adjusters. If caught early in the rattling, the check valve will protect it from further damage but its life expectancy has already been compromised. If the rattle is not addressed, the adjuster will deteriorate faster and it can suddenly lose timing if the back plate slips on the camshaft.
Currently, I look after 3 M276 engines, and they are under a strict diet of 5K miles of oil changes and moved them to 5W 40 MB approved oil (recommendation from my Indy, and several forum members). Unfortunately, we followed the 70K miles oil transmission MB's recommendation, but moved to 50K miles for the 2012 ML, and so will be the next ones for the 2014 E, and 2015 ML.
I've changed the oil, with Mobile 1 European full synthetic ow-40. Even though the history reports said it had been done 3K ago. What I put in looked a little cleaner. What's the added benefit of 5W 40? I'm in the Southwest US heat, a lot of stop and go city, but only 6K miles a year. Thanks for that info on the rattles damage, it checks with everything I've read and seen. That's why I just went right ahead and bought the adjuster along with the tensioner and check valve.Last edited by GLKwanter; Jun 20, 2023 at 02:42 PM.
I do not think you will be able to fix the camshaft sensor wheel without removing the valve cover but if you do please post we all need to learn better ways.
I haven't heard anyone speak of replacing the guide above the chain. I am in a GLK350 2013 just for clarification not sure if that makes a difference.
Edit:
Wouldn't the timing chain need to be removed for the camshaft adjuster to move when the tensioner has slack and is removed? I haven't seen anyone complain of camshaft movement... Hmm
That sounds silly now that I read it. I know you know what you're talking about. I doubt I'll be able to show anything new I'm just hoping to eliminate the rattle.
I've changed the oil, with Mobile 1 European full synthetic ow-40. Even though the history reports said it had been done 3K ago. What I put in looked a little cleaner. What's the added benefit of 5W 40? I'm in the Southwest heat a lot of stop and go city, but only 6K miles a year. Thanks for that info on the rattles damage, it checks with everything I've read and seen. That's why I just went right ahead and bought the adjuster along with the tensioner and check valve.He stressed to never step on the gas until the car is really warm, i.e. hot. For turbo even more. If the large mass parts are not up to normal temperature, i.e. expanded/dilated completely, the smaller mass parts might rub a bit more --> wear. For a cold engine, a sudden step on the gas for the turbo and the turbine wheel may rub on the case and hell start to break loose. The wheel being so thin will dilate long before the casing does. Once hot, he said just enjoy it on the highway, BUT once back let it cool down, and drive it softly, before parking it. I think the last one is to prevent oil from sitting on extremely hot surfaces after the Italian tuneup.
GLK, I am now envious of non-turbo engine owners lol. You should have little difficulty with the tensioners and sensors on either side. Those were really among the easiest steps of my recent overhaul. Cam adjuster was a good bit more difficult given valve cover removal requirement.
@juanmor40 I am now trying to discern the root cause of my new p001685 code following cam tensioner/sensor/B1 intake adjuster replacement...any thoughts? I will make a separate post shortly...I also have delayed startup and my Eco light does not turn on by default (which would be great if not a symptom of a bigger problem lol)
As you can see in the picture (from a used part of Ebay), the plate is pressed on the camshaft; therefore, it can slip if the torque is "the right one" or because of a persistent vibration, i.e. rattle.
Here is a snapshot taken from a video about the M274 engine, same type of camshaft. Notice the arrow are pointing to the same relative position of the shaft, and see how far away/different is the position of the reluctor wheel . I bet that engine did not even start.
If the plate (whatever its name is) already slipped, the ECU will compensate as much as it can but it will trigger an error at some point. That error can be p001685. How do you know?
1 - Swap sensors between intake bank 1 to intake bank 2 --> Did the code move to bank 2? No -> Problem is not the sensor
2 - Swap solenoids between intake bank 1 to intake bank 2 -> Did the code move to bank 2? No -> Problem is not the solenoid
3 - Here is more difficult: adjuster or slipped plate? You know the adjuster test process, correct? Did it pass, i.e. did not jump when rotating the engine manually? If so, the plate has slipped.
4 - Say the adjuster failed, and it is replaced. Did test 3 say anything about the plate slipping? Only if the adjuster did NOT fail. if the adjuster failed, the plate's correct positioning must be checked visually; otherwise, you risk putting everything together and getting the code again,
, and need to reopen to do it anyways. Your call at that point5 - you open the valve covers and visually inspect the plate positioning, and it fails (there is a tool to check that). New camshaft is the MB standard procedure ( https://mbworld.org/forums/c-class-w...ml#post8457971); however, others have been creative to realign them. How creative can we/humans be? A lot: @Westlotorn just did it a few weeks ago, and here another one (https://www.benzworld.org/threads/p0...crank.3112839/ )
My 2 cents.
here is a video about what I talked about
Edit:
https://www.youtube.com/watch?v=mAk_QSfFRmI
https://cimg3.ibsrv.net/gimg/www.mbw...17f2b4db14.png
https://cimg4.ibsrv.net/gimg/www.mbw...b5bae3112a.png
My 2 cents.
https://www.youtube.com/watch?v=oE1oNZI5mss
In case you think it's a typo, here is the original document posted in another thread,
https://mbworld.org/forums/attachmen...743d1615087556
