A207 Seat Upgrade to Ventilated and Multicontour
Old May 1, 2019 | 11:31 PM
Silberdachs's Avatar
2012 E550 Convertible
Trying to change the seats in my A207 (leather heated) to the ventilated multi-contour ones. Installed the seat today and all "old" functions (movement, heater, neck heater, memory) are working properly.
After looking through multiple threads and dozen of google searches I hope someone can help or pinpoint me in the right direction.
Neither multi-contour, nor ventilation is working.:From looking at the wiring there seems to be some major difference, would a new harness solve this problem? VIN of donor vehicle: WDDKK7DF5CF173286
Hope some can help on this topic, otherwise maybe hard wiring the pump and ventilators. Will work through all the wiring and connectors on the weekend. Could someone provide the voltage and pin configuration for the pump?
Old May 3, 2019 | 04:24 PM
Could anyone provide me with the wiring diagrams for "WDDKK7DF5CF173286" seats? Would be a great help to start with.
Old May 9, 2019 | 11:13 AM
Short update:
- Ventilation is not working as the LIN bus wire is not existing in my car, will work and see if I can get a summer/winter solution through the neck heater/vent working with easy switch solution (behind back panel)
- Multicontour seat working through DIY solution. Got a small hand pump ($10) and adapters to manually inflate the seats air bags. Not the prettiest solution but no wiring needed and 3-4 strokes are enough to inflate one bag. Maybe helpful for people with broken air pumps as well.
Old Oct 13, 2024 | 03:04 PM
boxeswithknobs's Avatar
BMW 528i
How did this turn out for you? I had ventilated seats on my ML63, but got an '15 E400 which has heat + multicontour, but no ventilated cooling. I got the console switch panel, and know I need at least the seat back from a vented setup. Is the stock harness + SAM capable of supporting this? I see the seat settings in COMAND engineering mode. Interesting that the programming for the capability already appears to exist in both COMAND, the programmable console switch panel already.
