stuck driver BACKREST
Old Jun 28, 2019 | 02:09 PM
snupys's Avatar
e250 cdi
C207 E250 CDI 2013 AMG SPORTS COUPE Driver seat backrest stuck in forward position switch moves up and down but back rest switch wouldnt move backrest ? HELP
Old Jun 29, 2019 | 07:41 AM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Can you post a photo of the seat in the forward position, and the button you are referring to? There is also a C207 specific forum on this site where you may receive faster replies.
Old Jun 29, 2019 | 12:52 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to C207 forum...
Old Jun 29, 2019 | 01:32 PM
chassis's Avatar
2017 GLE350 4MATIC
Have you read page 110 of the owner’s manual? Try using the chrome lever on the upper part of the seat back.
Old Jun 29, 2019 | 02:44 PM
snupys's Avatar
e250 cdi
Yup being through nothing there help with my issue Problem started when daughter tried getting into back seat used switch instead of seat lever . Now seat switch wouldn’t move forward or backwards just up and down. passenger seat moves forward and back tried checking fuse box but no fuses are blown my thinking it maybe seat switch . Just hoping it may just need resetting
Old Jul 1, 2019 | 09:40 PM
chassis's Avatar
2017 GLE350 4MATIC
Update?
Old Jul 2, 2019 | 11:17 AM
snupys's Avatar
e250 cdi
Still no joy I have contact MB uk they suggest I recover vehicle to them to look at . This might be dumb question the seat switch run on one fuse ? in there different fuses for each switch ? And where is the driver seat switch fuse located on a c207 coupe Amg sports 2013 does any one know ? Or does anyone have a fuse chart for this vehicle.
Old Jul 2, 2019 | 09:27 PM
chassis's Avatar
2017 GLE350 4MATIC
Do you have memory seats? From the photo it doesn't look like it.
For memory seats:
- Check the interior fuse box in left of cockpit, fuses 116 and 126. 30 amp fuses. Circuit 116 is red/yellow and 126 is red/green.
For non-memory seats:
- Check the trunk fuse box, fuse f44, 30 amps, black/violet and fuse f45, 30 amps, black/yellow.
Diagrams:
https://www.benzworld.org/forums/c20...x-details.html
Old Jul 3, 2019 | 03:10 PM
snupys's Avatar
e250 cdi
Checked fuse f44&f 45 not blown think it just might the seat switch that needs replacing .Manage to get a w212 switch in error but on close examination the are very similar to the switch that’s on the car currently Does anyone think might able getaway with using a w212v a c207 switch .
Old Jul 3, 2019 | 03:55 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by snupys
Problem started when daughter tried getting into back seat used switch instead of seat lever. Now seat switch wouldn’t move forward or backwards just up and down.
You can try a hard reset by disconnecting battery ground line however, all electrical consumers must be switched off otherwise they may be damaged when the ground line is disconnected/connected. If this fails most likely you need to have someone pull codes and normalize seat using MB STAR (diagnostics).
File Type: pdf
Old Jul 14, 2019 | 08:36 AM
snupys's Avatar
e250 cdi
Switch removed
Switch removed
Switch new
New switch
New switch
Seat now moves
Problem solved my initial diagnosis was right seat switch needed replacement manage to get used switch on eBay £28 removed seat and seat side panel to access switch removed and replaced with new car now drive able . But I must have touch the airbag wiring as airbag lights now on bother
Old Jul 14, 2019 | 09:07 AM
chassis's Avatar
2017 GLE350 4MATIC
Good progress, thanks for the update.
