Door wood trim coming off
Old Jul 5, 2019 | 11:10 AM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
What glue or doublesided tape do u use to fix the wood door trim from coming off?
Old Jul 7, 2019 | 01:02 PM
northridgeaz's Avatar
2011 E550 Cab
I had the exact same problem.. See my solution at this thread
MBWorld.org Forums >Mercedes-Benz Coupes & Cabriolets >E-Class Coupe (C207) & Cabrio (A207)
Wood Grain Fix
Old Jul 7, 2019 | 01:04 PM
2011 E550 Cab
Sorry for the bad link.
I used Clear Gorilla Glue on my door panel that the wood trim was lifting on one of the ends. I had to buy one of those huge wood clamps, cheap at Harbor Freight, in order to keep it clamped while it dried. It has been 6 months since I did it and so far it has not come loose.
Old Jul 8, 2019 | 07:30 AM
mikey08's Avatar
11 E350 Cab, 18 GLS450
I used the same glue as posted in this thread. I had the exact same area coming up. I placed a bead in right inside and used a small paint brush and made sure coverage was on both sides etc. The glue took about 30 min so what I did to not hold the piece in place being lazy I carved a small wood piece to match the arch of the wood panel, placed a piece of non skid rubber on top and used a large vise clamp to clamp the piece.. Once all was dry I removed it and used alcohol to clean up an light residue of glue on the sides. Been 3 months and no issues..
Mike
Old Jul 9, 2019 | 09:54 AM
Harold1898's Avatar
2015 E400 Coupe
That is terrible. When you think Benz you don't think about bits coming off.
Old Jul 9, 2019 | 10:59 AM
mikey08's Avatar
Agreed.. However it may have just been a weak spot where they had limited glue coverage since its happening to many cars in the same spot. Way too late for me to say its under warranty.. LOL
Old Jul 9, 2019 | 11:59 AM
2011 E550 Cab
I also agree, but it could be the type of glue they used in addition to the area that they put it. Fortunately its an easy DIY fix.
Old Nov 6, 2020 | 08:37 AM
MuddyBlueJeans's Avatar
2011 Diamond White E550 Cabriolet P2 Sport Ash interior
my wife’s car (2011 E550 Cabriolet) is doing the exact same thing so I think it’s just a manufacturing flaw. It’s also started to do it on the dash trim as well...So not a good spot to put a clamp but may have to use the seat itself and an adjustable shower rod To hold the trim in place.
Old Nov 7, 2020 | 08:58 AM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
I used gorilla glue and the wood pieces peeled off a week later. Then I used gorilla glue double stick tape and four months later they’re still sticking together.
Old Nov 22, 2020 | 12:02 PM
audiowhiz's Avatar
E550 Coupe C207
Mine was peeling when I bought the car, so I had the dealer add it to the IOU list. They tried to glue it and it snapped in two.
They ended up replacing the whole door seat control unit on their dime.
Old Aug 19, 2024 | 07:56 PM
Roseqt's Avatar
2011 E350 Merecedes Benz Convertible
Tried to fix with th gorilla glue too! Mine broke!
Hello, I also have a 2011 e350 convertible and my wood trim is starting to peal off on the right door, left door and under the glove box. So I tried to do what it said on this link and use gorilla glue. It did not work. A few days later the middle part of the trim got hooked on something and broke. I have searched everywhere(except the dealer) for this piece and have not been able to find it. Does anyone know where I could locate this piece? I would need all three pieces.
Old Aug 20, 2024 | 11:48 AM
ibbij's Avatar
Bi-Turbo E550 Coupe (W207)
Try loooking on ebay. Here are the 2 door trim ones: https://www.ebay.com/itm/156089357419. I saw many options for center console trim as well. Just search "10-13 c207 wood trim dashboard" or "10-13 c207 wood trim door" and various options will come up.
Old Sep 16, 2024 | 11:20 AM
Barry O's Avatar
CLK63, E550, SL500 Silver Arrow,Corvette LT1,ZR1
Everyone who has this problem needs to call Benz who will refer you to NHSTB and have you report the problem. It is insane that the wood trim in all of the 4 door and wagons was replaced free of charge and the coupe and cabriolet owner get nothing. Doesn't make any sense.
