Warm Air From Vents (Not in AC mode)
I am constantly getying a warm air comming through my vents, even when temp is set to low. AC works fine, when set to cold it blasts cold air when set to hot it blast hot air, so no issues here. Moment I turn AC off.... All Im getting is warm to hot air through the vents.... As you can imagine its getting quiet warm inside the cabin...
Is there any comon fault/ issue on MB e class with regards to the above?
Many thanks All
On the other side, during colder mornings (Temoerature outside 17C) the air is set to low and zi do get colder air from the vents.
What I expect to see (Forget the AC/CC - lets park that for now) is a cold/ cool air coming through my airvents when the temperature is set to LOW, instead I am only getting warm air, unless its a cold morning. If this was to remember previous settings, surely it would remember LOW setting from the previous day/ ride right? but instead it pumps warm air in..
In fact it pumps as cold/ warm air as outside air at that point in time (thats how it feels like)
There is ofcourse possibility thaf I missunderstood your post so let me read it again Lol
Sound like its working as it should, warm air during hot days in because CC is off.
On the other side... Today much cooler day, so colder air getting inside but I also felt very hot air from under the steering wheel area getting into the cabin... Engine compartment heat. Is there anything on these cars to lool out for in this case? Engine temp always fine so I presume thermostat and the rest is ok. Engine does not overheat but I do feel its heat inside the cabin... Even though colder air is getting through the vents.
Today temperature outside was 19C so I drove on the motorway without AC hoping for kind of same temperature inside the cabin but it was boiling hot on the drivers side. Blower turned off, etc and I still felt this heat...
