Need help with 2013 E550 Coupé mods
Old Sep 2, 2019 | 08:22 PM
Citybuild122's Avatar
2013 E550 Coupe Designo Edition, 2012 E350 Coupe, 2014 C63, 2018 GLC 300
Hey guys, coming to you with a few items I’d like to install on this vehicle, but have proven to be difficult to find.
1. AMG style front, side fenders. I’d really like to have fenders with the “dip”, where the V8 logo goes.
Do the sedan and coupe have the same size fenders? If so, could I simply install some from an E63?
2. AMG gauge cluster. This is probably the most difficult item here, but I’d really like to have the gauge cluster off of an E63. Has anyone successfully done this? Will it even work? Will it even fit?
Old Sep 2, 2019 | 08:31 PM
ItalianJoe1's Avatar
2003 CL 600
No, coupe architecture is closer to the 204 chassis than the 212, so you may have to look into fitting 204 AMG fenders if you wanted but i'm sure they are different.
The cluster, issue will be programming. It can be done but the coding to make it work correctly will have to be aftermarket as no dealer will have access to that type of swap, at least not in the US.
