Rear speaker grill removal
Old Sep 13, 2019 | 09:42 PM
TODD Davies's Avatar
2014 a207
Anybody know how to remove the rear speaker grills?
Old Sep 14, 2019 | 09:38 AM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
My A207 rear grilles are silver and have some discolourization near the rear of the speakers. I would like to know how to remove them too.
Other wise I am going to tape everything and try to paint them silver. Dont want the paint to hurt the speakers though.
Milburn
Old Sep 27, 2019 | 01:09 PM
konigstiger's Avatar
'71 Pinto
Tape surrounding surfaces and carefully pry up/loose using plastic wedge, note even speakers are replaced (no screws) from top.
Old Jan 31, 2022 | 03:19 PM
BigMike62's Avatar
2011 E550 Cab
Does anyone have a picture of the rear grilles removed? The front edge of the grille is exposed and I tried to lift it off and it wasn't budging. Has anyone actually removed them? Thanks.
Old Jan 31, 2022 | 03:34 PM
BigMike62's Avatar
2011 E550 Cab
Never mind. If you lift gently on the front edge, then slide forward and they come right off.
Old Jan 31, 2022 | 04:40 PM
WRC-LVR's Avatar
lift at the rear of the grilles slightly then slide them forward, the tabs point back IIRC
Old Feb 1, 2022 | 07:28 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Does anyone know how to remove the rear parcel shelf cover/speaker grille from a 2016 C207? I'm trying to locate a rattle back there.
Old Feb 1, 2022 | 09:07 AM
'71 Pinto
Carefully pry up using plastic wedge.
File Type: pdf
File Type: pdf
Old Feb 1, 2022 | 09:12 AM
Mr. Toad's Avatar
Thank you for this, konigstiger. I have tried prying it with a plastic tool before and it feels like I'm going to break some plastic fastener. I can't tell from the picture; is there anything that will crack?
Old Feb 1, 2022 | 09:23 AM
'71 Pinto
Clip or two if not carefully released.
Old Feb 1, 2022 | 09:24 AM
Mr. Toad's Avatar
Yep, that's what I thought! How do you "release" the clips?
Old Feb 1, 2022 | 09:29 AM
'71 Pinto
If you are unable to press towards center for release remove shelf to release from bottom, see attachments.
