Code P0128
Old Nov 27, 2019 | 10:22 AM
mikey08's Avatar
11 E350 Cab, 18 GLS450
Code P0128
Folks,
Getting a P0128 code for temp not reaching the range in time specified (2011 A207 E350). Know it may be either a thermostat or engine coolant temp sensor.
Anyone with any experience with this code and did a thermostat replacement fix the issue or should I just replace the temp sensor to see if that does the trick,
Funny thing is I got this code last year at the same time when outdoor temps are a little cooler and reset it and never saw it until this year again...
Any insight or experience with this code would be helpful.
Old Dec 4, 2019 | 03:31 PM
mikey08's Avatar
Folks, going to replace the thermostat housing but might just as well replace the temp sensor while I ma at it.
Anyone have a diagram where I can locate the coolant temp sensor 2011 A207?
Old Dec 5, 2019 | 09:11 AM
konigstiger's Avatar
'71 Pinto
Part # 0009056102 located towards the rear on the left cylinder head.
Old Dec 5, 2019 | 09:27 AM
mikey08's Avatar
Thanks !!!!
Old Jan 2, 2020 | 02:03 PM
mikey08's Avatar
All,
I did replace the thermostat housing and was fairly easy and all done with cleanup within 2 hours... I reset the code and so far has not come back..
Cheers Mike
Old Jan 6, 2020 | 02:58 PM
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
Hi Mike, what parts did you replace? I have the same error code. Also any tips for installation? Thanks
Old Jan 6, 2020 | 03:11 PM
mikey08's Avatar
Kev,
I replaced the part with this:
https://www.fcpeuro.com/products/mer...ostat-4834100d
Its the Wahler housing and it came with the housing..
Well in summary:
Removed the antifreeze cap. COLD CAR
Took the blower motor off.
Removed the serpentine with a 17M wrench just slightly counter clockwise of the tensioner bolt and removed the serpentine
Removed the top pulley that blocked the bottom bolt of the housing.
Removed the hose from the housing and quickly placed the hose into a narrow bucket I placed below. I only lost about 3/4 of a gallon of antifreeze.
I removed the bolts to the therm housing and just lightly tapped it with a rubber hammer and it came off.
One thing I did was used was some alcohol to remove every bit of the old gasket.
Replaced everything in reverse.
Filled antifreeze back up etc.
I had no leaks and one thing I did do is run water over all serpentine pulleys to wash any antifreeze that dripped on them before placing serpentine back on. I used my compressor to blow the pulleys dry... I know a bit over the edge but that antifreeze can eat at anything especially if left on a belt...
I used the guidelines from this VID and added my own elements along the way. I removed my blower motor first however.. You can do it as you see fit. Enjoyed doing it. Only about 2 hours total with cleanup etc.
https://www.youtube.com/watch?v=jMmc...M#action=share
Hope this helps.
Mike
Old Jan 6, 2020 | 03:21 PM
Kevin9664's Avatar
Thanks, Mike. Very helpful. Will probably look to do this spring as it gets warmer.
Old Jan 6, 2020 | 03:23 PM
mikey08's Avatar
Sure thing.. Just ping me or message me if you need any added help.
Mike
