2011 Mercedes E550 Cabriolet -- engine light-- coolant temperature sensor malfunction
Old Jan 30, 2020 | 07:10 PM
Skbrod's Avatar
2011 Mercedes E550 Cabriolet Sport, 2019 GLE400 4MATIC
Hey guys,
Thought I'd try over here first to see if it can be done without the dealer seeing as they want 170 an hour just to "diagnose" the issue smh...can I change the temperature sensor myself? What needs to be done exactly? I hooked the obd to it and that's what it read but it was a basic obd so idk, what do you guys think? I just have to eat the cash for it?
Thanks!
Old Jan 31, 2020 | 10:44 AM
mikey08's Avatar
11 E350 Cab, 18 GLS450
What code are you getting and is your check engine light on?
Old Jan 31, 2020 | 11:53 AM
konigstiger's Avatar
'71 Pinto
If, in fact, it is the coolant temp sensor it is plug & play replacement. After install, if code remains stored erase if you have the ability.
File Type: pdf
Old Feb 15, 2020 | 12:20 PM
Skbrod's Avatar
Nice thank you guys. For some reason, the check engine light just turned back off one day and hasn't come back on yet. It's been 2 weeks, so hopefully everything worked itself out haha
Old Mar 20, 2020 | 04:02 AM
yaknart33's Avatar
2010 E550 coupe,2005 porsche ca 911,04 subaru outback,94 Harley FXSTC
Your thermostat could be sticking open causing the temp sensor to read cold for to long.The code indicates a system that failed not a component.That's why you have to find cause,correction ,retest .
Old Mar 20, 2020 | 09:02 AM
mikey08's Avatar
This may help... Had the same issue if the code you are getting is the same.. This was on my 2011 E350.
https://mbworld.org/forums/e-class-c...ode-p0128.html
Old Mar 30, 2020 | 01:55 PM
WIN ER's Avatar
2007 S65 AMG (W221)
Had the same issue: on-off-on. In fact you will only get the MIL light when it's cold outside. Turned out to be the thermostat which is also an easy fix.
