C207 Headlight different color
My E Coupe C207 have steering lights, maybe this can help.
I tried to disable the active lights but it's the same.
Changing the ballast is hard?
I had the same problem with my e350 coupe. The right headlight was bright white while the left headlight was more yellowish. I swapped the ballast from left to right and right to left, the problem was still the same. Then i switched the whole headlight unit meaning i removed the driver side headlight from the right side to the left side and vice versa to see if there was a problem with the outer wiring of the headlight but it was still the same. Anyways, if you would like to try to swap the ballasts like i did from side to side it is very easy, first thing you need to do is to remove the front bumper, and the ballasts will be right under the headlight as i recall. They have only 2 bolts holding them in place.
As a conclusion, i think that the problem is something realted to the inner headlight components. What i did to fix the problem about 80% is i put a higher kalvin unit xenon bulb on the passenger side (yellowish side) so that it would resemble the driver side. It is not 100% accurate but it is better than before. I put 4700k bulbs on the passenger side, and kept the original osram 4300 bulbs on the driver side.
Hope this was helpful.
