E350 Coupe handling problem.
Old Sep 16, 2021 | 01:31 PM
alfie6447's Avatar
E350 Coupe
Hi all.
I've got a 2010 E350 Coupe.
I've just had some new tyres fitted, Uniroyal rain sport 5's, but they seem to have completely ruined the feel of the car.
Going around a long bend at 60mph seems to have become dangerous, it's almost as if the tyre is not gripping at all, the traction light also seems to be coming on quite alot now. The back end feels all over the place. I've been assured these tyres are the best on the market, and the fitter also tested the car and said he can't feel anything.
Has anyone had this problem before? It wasn't like it on the old tyres, and I've checked the suspension components for movement but there isn't any.
ThankyouAlfie
Old Sep 16, 2021 | 03:23 PM
pca7ggr's Avatar
'11 E550 Cpe/'04 GT3
Allie,
Check the tire pressure. If needed adjust to the recommended.
Old Sep 20, 2021 | 10:19 AM
Paul Shalom's Avatar
E400 W207 C320 W203
Uni-who??
Old Sep 21, 2021 | 12:10 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
UniRoyal IIRC owned operated by Michelin
Old Sep 21, 2021 | 05:54 PM
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Looks like its probably just a characteristic of the tire.
https://www.tire-reviews.com/Tire/Un...ainSport-5.htm
There are several more reviews I was able to find with similar conclusions. Seems it's a great wet weather option, but doesn't quite cut it as a performance tire in the dry.
Old Sep 23, 2021 | 11:49 AM
WRC-LVR's Avatar
here =>
Latest Tire Test Results
2021 ADAC Summer Tire Test - 205/55 R16 - 13th of 15 tires
  • Positive - Good in the wet, relatively low fuel use.
  • Negative - Weak in the dry, high wear.
  • Overall - The Uniroyal Rainsport 5 has significant weaknesses in the dry with imprecise steering, low grip, and long dry braking distances. The RainSport 5 is still good in the wet, with short wet braking and high aquaplaning resistance. The tire also has low noise, low rolling resistance, but high levels of wear
Based on that those would be a down grade from most tires, but very much so from high performance summer tires
Old Sep 23, 2021 | 11:56 AM
E400 W207 C320 W203
Originally Posted by WRC-LVR
here =>
Agreed.
Old Sep 23, 2021 | 07:03 PM
Dnasty's Avatar
2010 e550 coupe
I just googled your tire and this is the first thing that I saw.
Overall - The Uniroyal Rainsport 5 has significant weaknesses in the dry with imprecise steering, low grip, and long dry braking distances. The RainSport 5 is still good in the wet, with short wet braking and high aquaplaning resistance. The tire also has low noise, low rolling resistance, but high levels of wear.”
Seems to be characteristic of the tire.
