What mpg are you getting?
Old Dec 9, 2021 | 06:50 PM
Dnasty's Avatar
2010 e550 coupe
I’m currently getting around 12mpg granted I’m in Los Angeles this still seems pretty bad. I have a 2010 e550 coupe.
Old Dec 9, 2021 | 08:41 PM
pca7ggr's Avatar
'11 E550 Cpe/'04 GT3
I’m getting high teens around town and 25mpg on long trips. That’s driving like I own it - ;>
Old Dec 9, 2021 | 11:07 PM
Dnasty's Avatar
2010 e550 coupe
Originally Posted by pca7ggr
I’m getting high tees. Around town and 25mpg on long trips. That’s driving like I own it - ;>
Are you going off the mpg info on the dash? I'm guessing you have the twin turbo that gets slightly better mpg.
Old Dec 9, 2021 | 11:34 PM
pca7ggr's Avatar
Yes, I am using the dash mpg. And, no, don't have a twin-turbo - just good old naturally aspirated 5.5ltr.
"No replacement for displacement."
Old Dec 9, 2021 | 11:37 PM
Dnasty's Avatar
2010 e550 coupe
Hmm seems we have the same vehicle... Wonder why i'm getting such poor gas mileage.
Old Dec 10, 2021 | 03:54 AM
route246's Avatar
2011 C207 E550
Barely hitting 20mpg
50:50 city/highway can’t make it above 20mpg yet…. I haven’t had a chance to do an extended trip so I’m looking forward to seeing those numbers somewhere north of 20 in the future.
Old Dec 10, 2021 | 10:05 AM
EthereJim's Avatar
2011 E550 Cabriolet
dumb question, but how can you see the MPG you're getting?
Old Dec 10, 2021 | 10:28 AM
Dnasty's Avatar
2010 e550 coupe
which app is this you are using?
Old Dec 10, 2021 | 10:30 AM
Dnasty's Avatar
2010 e550 coupe
On the main dash screen one of the option shows you your accumulated mpg after starting the car and another after a longer period. If you tap down on the trip odometer section.
Old Dec 10, 2021 | 04:21 PM
couped_up's Avatar
2013 E350 Coupe [C207]
I typically hover between 9-11 L/100km which is ~21-26 MPG i believe
Old Dec 11, 2021 | 01:34 AM
route246's Avatar
2011 C207 E550
Fuelly.
Old Jan 29, 2024 | 04:19 PM
nkx1's Avatar
2010 E550 Coupe
Sorry to resurrect this thread, but I figured it's better than starting a new one.
I'm maxing out at around 22 mpg (per the dash display) with mostly freeway driving. This is going an average of maybe 70-75 mph, maybe a little faster in some stretches. This is for a 2010 E550 Coupe. This is noticeably worse than my 2008 CLK550 (same exact engine and transmission, only very slightly lighter car) which got 25-26 mpg for the same type of driving.
Given that my CLK did so much better, I wonder if there's an issue with my E550? Maybe wheel bearings or something? Kind of odd.
Old Jan 29, 2024 | 06:26 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
22 seems reasonable to me. You can't trust the dash btw, gotta measure actual gas used. I've been measuring each tank for like six months to get an avg because it usually varies ~5% each tank, but sometimes more than 10%. A couple weeks ago it was 14.5%.
The dash on my car doesn't measure the gas used, but seems to be estimating by using engine load. I'd imagine if something was wrong and it was using more gas, but same load, it wouldn't see that. Whatever the deal, my experience with any car with a dash readout is it's just a guesstimate that can be anywhere from very close to very wrong.
Old Jan 29, 2024 | 07:25 PM
nkx1's Avatar
2010 E550 Coupe
Yeah, it seems somewhat reasonable, and I know the dash can't be trusted entirely. But I was comparing the dash calculations of the CLK550 to the E550, which I would assume are using the same/similar means of calculation. And based on that, the E550 seems to do 3-4 mpg worse than the CLK despite being an extremely similar car. Oh well, I guess it is what it is unless some deficiency is found.
Old Jan 30, 2024 | 05:25 AM
pl626's Avatar
2015 E400
I've found 65-70 mph is the sweet spot for my 2015 E400. When I cruise in this range on flat terrain, MPG is easily above 32.
Old Jan 30, 2024 | 08:28 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Same here.
Old Jan 30, 2024 | 10:21 AM
Chevota's Avatar
the point was basically the one might be reading better than the other. id imagine the e weighs a good bit more, and aerodynamics, tires and pressure, alignment, gearing and who knows what else is different.
Old Feb 1, 2024 | 10:26 PM
Hee-Haw's Avatar
2014 E350/C207
29.0 mpg overall for the last 63,000 mi
I live in the country.
I don't use AC in cool months.
I drive like an old lady now. (I'm an old man. lol)
Old Feb 2, 2024 | 06:43 AM
pl626's Avatar
2015 E400
This is about right for a V8 sitting in the i5 parking lot...
Old Feb 6, 2024 | 04:41 PM
Chevota's Avatar
Now that I burnt through my first tank of pump gas (E10) in a while, my actual mpg was 20.07 and the dash read ~23.5 to a high of 25.9, so I guess 24.5 avg?
So on pump gas the dash is reading ~22% high. Not sure how much longer I'll run pump gas but I will track it if I do. My usual of ~50% Ethanol the dash reads ~45% high.
The live reading is even worse, I believe, because if I do find a rare stretch of flat ground it reads ~30. There are basically no flat spots where I live so flat to me is some fraction of a degree up/down, but that fraction of a degree makes a big difference in the reading. I've used GPS to see how flat my nearest flat spot is, but gps is worse at elevation than my dash is at mpg, so I guess I'll never know what the angle is.
