Going from 275/30/19 to 265/35/19 in rear will this cause any issue?
Old Jan 23, 2022 | 11:25 PM
Dnasty's Avatar
2010 e550 coupe
I have a 2010 e550 coupe w207 RWD and while I know 275/30/19 is a size many have tried and works well I am wanting to go 265/35/19 on the rears for a better ride and some more meat. My car is a rwd not awd so I am not sure if there are any computers that would be afffected by this jump in size. It does create about a 1.9% difference between the front and rear diameter making the rears slightly taller than the fronts (I may change the fronts to suit as well later depending). I have heard some mention possible traction control issues and speed sensors causing the car to go into limp mode if I deviate too much but not clear on if this related to rwd cars. Appreciate any help on this and yes I did check out the offset/fitment thread and does not seem like anyone on there has tried this. Thanks
Old Jan 24, 2022 | 12:32 AM
Siegmann's Avatar
10-second E550
You'll be good. I've run rear tires more than an inch larger in diameter than fronts without issues.
Old Jan 24, 2022 | 02:12 AM
Dnasty's Avatar
2010 e550 coupe
Do you think the w207 can fit 275/35/19?
Old Jan 24, 2022 | 06:28 PM
Siegmann's Avatar
10-second E550
I run that size without issues.
Old Jan 24, 2022 | 07:59 PM
Dnasty's Avatar
2010 e550 coupe
Do you happen to have any pics? I've been trying to find someone running a 35 in the back but most everyone is running 30 aspect. I have a 38 offset in the rear so was thinking I would have to go with 265/35.
Old Jan 24, 2022 | 08:33 PM
Siegmann's Avatar
10-second E550
That's an aggressive offset. You may have tire vs wheel arch issues with 275s.
19x9.5 +56, 275/35:
Old Jan 24, 2022 | 09:41 PM
Dnasty's Avatar
2010 e550 coupe
19x9.5 +56, 275/35:
Thanks... do you think I could fit 265/35 with my offset? I actually don't rub with the 275/30s unless I hit a major dip and I'm also lowered a great deal (I plan to raise it about 1.5-2" when I go up aspect size).
Old Jan 27, 2022 | 04:35 PM
m1l3n's Avatar
2013 C300 4Matic
You got a picture? im curious how 38et looks with 275/30
Old Jan 27, 2022 | 05:40 PM
Dnasty's Avatar
2010 e550 coupe
Ill see if I can get one. There are a few users running my same setup on the offset thread though. It fits pretty much flush with the fender maybe 1-2mm poke.
Old Apr 16, 2024 | 05:38 PM
604550C207's Avatar
C207 550
just want to confirm that this will work:
ET 35x8.5 Inches squared
255/35/19 Front
275/35/19 Rear
Thanks.
Old Apr 16, 2024 | 05:54 PM
Siegmann's Avatar
10-second E550
255/35/19 Front
275/35/19 Rear
Thanks.
The 275 is wide for 8.5" wheels IMO. It would work, but slightly bulged. 255 fits fine on 8.5"; if you're lowered, it may rub a little in the front when cornering, with that offset.
Old May 7, 2024 | 02:07 AM
604550C207's Avatar
C207 550
19x9.5 +56, 275/35:
Does that mean you ran 40s in the front? or still 35s? Also, is that stock suspension?
