50 weight oil on a w207 550?
I use Amsoil 10-30 + straight 60 + Lucas syn + a little Zinc and Tungsten. So you can make any wt oil you like
our newer engines are built to closer tolerances and designed to run on lighter weight synthetic oils, like the recommended Mobil1 0-40 “European Blend”. I run this on both my ‘11 E550 coupe and ‘04 GT3. Neither runs hot unless I’m stuck in bumper-to-bumper traffic.
Have you checked the condition of your coolant? How many miles since the coolant system as beeen flushed and e placed with the recommended coolant?
50 weight won't meet the MPG stipulations of 229.x. except in the case it's blended specifically to do that....but not a desirable solution since adding the spec adds to the price and compromises the formula.
Engine design and the temps require LESS than the 3.5cP of a 5w-40 or other spec oil. The spec allows for excess heating and thinning of the oil on the Autobahn specifically. We don't heat the oil up in North America so much, out side of towing and hill climbing. So the benefits of going even thicker don't even come into play for LA driving. The only benefit is smoothness and quiet running. Maybe a better ring seal too, which adds up to a nice experience.
So you do NOT need a MB spec 50 weight. MB spec is simply for extended service, mpg and wear plus deposits.This tool helps compare specs... https://online.lubrizol.com/relperftool/pc.html
At a minimum, any jug 50 weight will meet ACEA A3, 15w-40 HD diesel oil does. It's the basic generic spec the mfg specs build on. I would use 15w-40 ALL FREAKING DAY in that engine and climate. Rotella is most popular, Chevron Delo or my pref Mobil 1300S. Without a turbo, MB will run on ANY oil in the store, provided climate and service length are observed. People here are silly, and don't realize MB spec oil is just for extended drains, that's it. Normal oil is FINE.
Other oils I would consider in 50 weight are Valvoline SynPower, Valvoline Maxlife, Quaker State or Castrol. High Miles oil will help out with the seals conditioning them, and would be most optimal. MaxLife has low volatility, which is all you need. Wear is not an issue, MPG is not an issue, nor are deposits. Modern oils will not sludge up or leave deposits in non-turbo engines at normal 1q/1000mi intervals.
So,imo try 15w-40, it's like $2/q with modern Mercedes HD specs....also approved for gas. Also I would also say MaxLife 20w-50 and / or 10w-40....a mix ideally. The 10w-40 Maxlife is already very thick for a 40. A spec 0w-or5w-40 is about 12.9cP, where Maxlife 10w-40 is more like 15cP. It alone is pretty much perfect if you want to keep mpg up and it has the seal conditioning you need.
Sometimes I get a jug of 5w-30 and one of 10w-40 and mix the whole jug of heavy oil in summer, and the whole 5q of thin oil in winter. For you that would be five q of 10w-40 and three of 20w-50....that is still excessive visc, but will keep internal wear down.
Consider getting an oil extractor pump. They pay for themselves the first time you use it.
Il'l check back in case anyone has a question.
I just brought this home an hour ago, with the 3.5 DI... I grabbed 2 gallons of Mobil Delvac 15w-40 for $10.99 each....and that's what I am using for the summer. if you try it, I don't think you will have any complaints about smoothness.
https://www.mobil.com/en/lubricants/...0-super-15w-40
Here's the PDS... https://www.mobil.com/en-us/commerci...0-super-series
Maxlife runs very smooth too, you should try it in 10w-40 maybe with some 20w-50 if you still want to try that approach, without going overboard. Volatility is either 10 or 11%, which is the same as required in Euro specs. Over there, 10w-40s are commonly licenced spec oils.
Opie Oil has a lot of data, you can reverse infer what works...
https://www.opieoils.co.uk/c-657-10w40-engine-oil.aspx
https://www.opieoils.co.uk/p-87258-v...ngine-oil.aspx
- Approvals / Performance Levels:
- API: SM, SN, CF
- ACEA A3/B4-10
- MB 229.3
- PSA B71 2300
- Renault RN0700/0710
- VW502.00/505.00
- Fiat 9.55535.G2/D2
https://www.opieoils.co.uk/c-647-eng...viscosity.aspx
https://www.opieoils.co.uk/c-680-eng...ification.aspx
See, oil companies pay $$$ royalty fees to mfg to list their specs on the bottle. It's a very different process than people think. That's partly why we see less licenced products in the USA.
Again, once you are dealing with 40 and 50 weight oils, don't worry about mfg specs.
I have the na 550 engine, this oil would still be fine? Also is 15w40 actually thicker than 5w40? I thought that was just at startup.
I did actually know about the fee they pay to put that expensive 229.5 badge on their oil… guessing that’s why the one 50 weight that shows it is so costly.
You can't go wrong with either 15w40 HD or Maxlife 10w-40 either one will work better than the 5w-40s or 0w-40s in your app and climate. You don't need the cold starting of the synth grades, nor the supposed mpg gains. Look at it like this, if you were tracking your car, a 0w or 5w-40 would do nothing for you. If you were granny driving 2 miles in bitter cold to church in Minnesota, sure 0w-40 or even better a 5w-30. Move to Alaska when it doesn't get above -20C and your engine never warms up fully....0w-20 might be the ticket. Your application is the opposite of that...still, a 20w-50 is just too thick, imo. You might want to do lab analysis on your used oil to compare, but wear will be minimal with the thicker oils, wear tests are to see how THIN you can go without excess wear. The default is always slightly thicker for good wear.
https://mbworld.org/forums/e-class-c...ught-home.html
- Extended oil drain interval (ODI) potential up to 1.5X the average OEM ODI recommendation*
- Up to 50 percent more wear protection than required in API engine tests
- Outstanding oxidation stability
- Excellent soot and viscosity control
Mobil Delvac 1300 Super 15W-40 diesel engine oil is recommended by ExxonMobil for use in:
- The latest heavy-duty diesel engines, including those equipped with aftertreatment systems and EGR
- Diesel applications using older and naturally aspirated conventional designs
- On-highway heavy-duty trucking and off-highway applications including trucking, mining, construction, agriculture and marine
- On-highway applications operating in both high speed/high load and short haul pick-up/delivery service
- Off-highway applications operating in severe low speed/heavy load conditions using up to 500 ppm sulfur fuels
- High-performance gasoline engines requiring API SN and mixed fleet operations
- Diesel-powered equipment from American, European and Japanese OEMs
https://www.mobil.com/en/lubricants/...ileage-10w-40/
Damn, the HT/HS isn't published anymore. I think it was pretty crazy, like 4.7cP or at least 4.5 or 4.1 Anyway it's 15.3cSt while 0w-40 cold start / mpg oils are more like 12.9 cSt, and most sheer to a 30 weight rapidly.
https://www.mobil.com/en-us/passenge...h-mileage-oils
Just look for the PDS Product Data Sheet for whatever oil you want specs on. Sometimes called a different term...I don't remember.
Anyway, it's the bomb. I was thinking about Maxlife 10w-40 since there's a 20w-50 to blend it with. Either way, you have some good options w/o rushing to a 50 weight.
