Marker Light
Old Aug 28, 2022 | 11:21 AM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
Marker Light
I have a 2012 Cabriolet and am wanting to replace the orange marker lights. How do you remove these marker lights?
I can reach behind the light and there appears to be a clip. When I release the clip, the back part of the light loosens, but I can not see how to actually remove it.
Old Aug 28, 2022 | 01:16 PM
konigstiger's Avatar
'71 Pinto
Old Aug 28, 2022 | 02:20 PM
Davery's Avatar
Are there two screws? Does the light need to be unplugged to remove the housing? If not, it looks like it should just swing out after the tab has been disengaged.
Old Aug 28, 2022 | 02:25 PM
'71 Pinto
As it appears in photo lens is hinged, release locking tab unclip on hinge side.
Old Aug 28, 2022 | 02:49 PM
Davery's Avatar
From looking at the pic you posted which includes both the front and back piece, I may need to unclip the wiring harness. It looks like the front piece may not be able to swing out after releasing the locking tab if it is still plugged in. The pic I posted is of the new marker light. I'm not sure how that wiring harness fits into the pic you posted.
Old Aug 28, 2022 | 03:06 PM
'71 Pinto
It appears replacement is not compatible. Here’s 212 same for 207, only two wires to existing socket.
Old Aug 28, 2022 | 03:27 PM
Davery's Avatar
https://youtu.be/pCP1ecrqe68
These are LED. and I am assuming I would remove the bulb and plug the new marker light into the bulb receptable. But until I get it out, I don't really know.
Old Aug 29, 2022 | 11:37 AM
604 C63's Avatar
2012 E550 Cabrio
Its sort of...pressure fit in there. Crank your steering all to one side for access and pop the fender liner loose. When you press that tab on the left, the back half sort of hinges on the right there and then will come out.
