E550 Coupe Downpipes
E550 Coupe DP’s
The only company I know of making them that will fit is from Weistec nice work, expensive.
Why do you want to change them? If you do, you should address cats, and the whole exhaust, including an x pipe. If you’re looking for more flow and power, Tune it.
If that’s not enough, then do the exhausts or do all at the same time.
there’s a lot you can do but the cheapest and easiest is a dyno and road tune.
Ryan
Ryan
I've been eyeballin these: https://vrpspeed.com/product/blcgedps
I have no doubt they are a monumental pita to install and likely involve pulling the engine. Maybe someone chan chime in with better news because I won't be doing that
I wrote the company with a few questions about the exhausts
The welds look good. The description didn’t list the material used, nor the gauge of the steel tubing. As to the cast flange, I don’t know if the cut the OEM off and weld them or if those are a custom cast.
It should be a minimum of 304 stainless, if not 321 (over twice the material cost). Mild steel is not recommended for turbo exhausts as it does nit have the heat resistance properties necessary for the high heat produced by turbos.
I’ll update with what I find out.
Weistec: https://www.weistec.com/m278-downpip...-e550-rwd.html
Ryan
Installing Downpipes
thanks for the link. I was unfamiliar with that company…Looks like a well made set up. You can see the flange that connects to the turbo header is cast and looks like a matched transition from the header to the downpipe.
Ryan
Ryan
i m contributing to this thread as I’m working in my final plans for my turbo upgrade project so I’m interested and considering fabbing my own.
will be interacting to see how it all turns out.
Ryan.
2012 E350 Cabriolet now SOLD to my son
Wrapping the header will retain heat in the exhaust (good) and lower the rate of heat transfer to the engine compartment (good). Retaining the heat will allow the turbos to spool better ( good ) but the tune may have to be adjusted for the better exhaust flow and changed boost curve ( need to do this anyway but $$ ). Since there is a lack of space, there may be interference fitting if wrapped ( bad) Interference fitting can cause the wrap to fray and wear (bad). Lastly, substandard construction and use of wrong weld filler can heighten the possibility of cracking the flanges or tubes (bad)
If this is an engine out fit, one might want to think more in-depth and get a cat back with x or h pipe and a dyno and tune. less work less $$$ and less time involved..
I found some pix to give us a better idea. Two different pix of the right side. I didn't find one for the left without the downpipe like this. It doesn't look too bad since that top bolt is accessed from the front. The pix are big on purpose so people can see all the little details they need.
The motor mount will clearly be in the way, so once that and the exhaust are out I kinda have a warm fuzzy. Except for two things; can I get the motor mount back in after, and ex bolts tend to break, like the one in the pix one did...
Then the VRP pipe for comparo, which doesn't seem like a big deal to bolt in? I do wonder about all the pipes, how they go together because the connections look weird. I'd assume it comes with the clamps or whatever but I've been burned too many times to assume.
If I did this in my driveway will my remaining oem exhaust simply bolt up to the end of this? I'm sure the answer is no but maybe I'll get lucky.
Link I found these, or one of them. Fyi used parts on ebay often have detailed pictures at various angles if ever in need
ebay.com/itm/125514079482
WRC-LVR (01-18-2023)
