Remove Glovebox
I don’t know if you need to remove the glove box or not, but I needed to.
Boy, I sure could have used the the instructions for removing the glove box! The one screw I did not see was on Step 5: Remove bolt (6).
I was having the exact problem you are having - the blower motor was getting somewhat hung up on the glove box.
Like I said, I did not have the instructions for removing the glove box; however, I figured out enough of it (except that one step) to at least loosen it up to move enough of it out of the way to be able to remove the blower motor and put the new one in.
I have to say, without being able to pretty much lay down in the footwell and see what you are doing seems like it would be a lot more difficult.
But good luck!
(Edited: Well, I can see how if you are able to fully remove the glove box then laying down in the footwell is possibly not necessary.)
But good luck!
