No power to trunk lock
Old May 2, 2023 | 10:28 PM
Mikebel's Avatar
2005 S500, 2013 E350 cab
Hi all,
Today the E350 car battery died and I had to jump it. I'll test the battery tomorrow. Before I jumped it, I had to use the emergency key to open the trunk. Even with the power restored, the trunk will not unlock via the fob or the door switch. No sound of "unlock" from the trunk.
Any thoughts on a solution? I thought maybe a fuse but I haven't gotten that far yet to check it.
Thanks!
Old May 3, 2023 | 05:11 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Originally Posted by Mikebel
Hi all,
Thanks!
Is the switch off in the glove box?
Old May 3, 2023 | 06:46 PM
Mikebel's Avatar
Elvis, Thanks but I don't see a switch in the glovebox.
Old May 4, 2023 | 04:43 PM
I don’t know your car but, usually there is a switch in the glove box to lock the trunk when you have to valet park.if you still use a mechanical key then I guess it’s irrelevant. This is for keyless start, where the only key is the one stored in the key FOB.
Old May 4, 2023 | 11:22 PM
Mikebel's Avatar
Thanks. Yes, mine is keyless as well.
Old May 5, 2023 | 12:21 AM
The switch is obvious in my car. Perhaps because it’s a convertible.
