Passanger side power seat..
Old May 7, 2023 | 09:39 AM
Snarla's Avatar
Mercedes e350 coupe
Hello all.
Yesterday I noticed that my passenger seat is no longer powered. Before I make an appointment with the mechanic, can anyone suggest what repair that I might be able to diagnose/fix myself? everything else is perfect. Many thanks.
Best,
Mark
Old May 8, 2023 | 01:44 PM
Snarla's Avatar
Mercedes e350 coupe
Update time!
I noticed that the power seat slides forward when I fold the seat back (chrome lever) flawlessly. Only the (passenger) door control is deceased. I would rather extract one of my husbands teeth...than tackle removing the door panel, so off to the dealer next week ( I guess?). I did use a flashlight to examine all connectors under the seat. All seamed to be factory fresh in every way ( especially cleanliness). Quite odd.
Kind advice very much welcome.
Best,
Mark
ps. whatdaya know about fuses? Drinks are on me. I do own a hammer.
Old May 8, 2023 | 08:44 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
Before I do that I'd check the fuse for that door switch.
Door panels are not difficult to remove, and the switches are easy access/replace as a general rule. Well, for me, because I do that sorta stuff. You I guess not so much?
Where the fuse is on your car I can't say for sure, but there should be a fuse box under the hood and one on the left side of the dash, which is covered by the door when closed. It's hidden under a plastic cover. The hammer will open it but I use my fingernails to get under it and pop it off. I can post a pix if you need. There are also some fuses in the trunk, behind a door in the carpet.
I'm going on memory for the fuse locations since I got rid of my '13 E350 ~3 years ago. Not sure what year yours is, it may be very different but probably not by much.
Old May 9, 2023 | 06:07 AM
Snarla's Avatar
Mercedes e350 coupe
So many thanks Chevota!
I'll start sniffing for the proper fuse.
Best,
Mark
Old May 9, 2023 | 02:13 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Yes there are fuses in the trunk :-). Look in the manual there may be a schematic for the fuses and locations. In any case, pull each one and check to see if they are intact and not corroded. Replace any if not squeaky clean or blown. If any are blown you may need to get the issue diagnosed....
Konigstiger on MBworld can help with info if you give him the VIN and year and what you need (location & issue etc)
He's a life saver :-)
Old May 10, 2023 | 07:41 AM
Snarla's Avatar
Mercedes e350 coupe
So many thanks WRC LVR!
Today is car wash day..I'll take a look inside of the trunk. But...I've never changed a fuse before..unsure how to remove the old fuse..and I am not sure how to determine if a fuse is bad. I will learn something today! Then I'll probably take it to the Mercedes dealer... hahaha.
Motor on,
Mark
Old May 10, 2023 | 08:46 AM
WRC-LVR's Avatar
here is a snip from my 2012 E350 A207 cabriolet manual. Note the locations of the fuse boxes and the location of the fuse identification chart itself.. You can get a minifuse puller plastic tool from any parts store for < $5...
The fuses are located in various fuse boxes:
fuse box on the driver's side of the
dashboard
fuse box in the engine compartment on the
left-hand side of the vehicle, when viewed
in the direction of travel
fuse box in the trunk on the right-hand side
of the vehicle, when viewed in the direction
of travel
The fuse allocation chart is located in the
vehicle tool kit ( page 290) in the stowage
compartment under the trunk floor.
good mini fuses have the tiny metal strip in the middle in a "u" shape
blown minifuses will show a burnt section with metal missing from the center
here is a link to a pic showing you what good and blown fuses look like
https://www.google.com/search?q=pic+...hrome&ie=UTF-8
Old May 10, 2023 | 08:54 AM
Snarla's Avatar
Mercedes e350 coupe
Excellent. I can do this!
to be continued.....
Old May 10, 2023 | 08:55 AM
WRC-LVR's Avatar
link to fuses and pullers on Amazon
Amazon Amazon
Of course you can..very easy...just remember if you find a blown fuse or damaged fuse to replace with the same rated fuse. if it fixes the issue your golden, if not at least you know there is an issue with that circuit.
I would recommend you invest in a good code scanner that can scan the car thru the OBD2 port and identify any issues. It gets very expensive having Mercedes diagnose your car and they arent always great at it.
Old May 11, 2023 | 07:47 AM
Snarla's Avatar
Mercedes e350 coupe
Good day all!
Last evening I located the fuse box in the trunk (passenger side) that hopefully will contain a bad fuse. I am slightly intimidated with this project, as there are so many fuses in the little box. The fuse puller that I ordered will be here in 3 days. Then I will put on my big boy underwear... and proceed.
Cheerio,
Mark
ps I spy what appears to be a few extra fuses in the box (I think). I know that the replacement fuse must be the same as the blown fuse. oh lord.....
Old May 11, 2023 | 11:54 AM
WRC-LVR's Avatar
Snarla
There should be a fuse chart in the trunk as well so you know which ones to look at
Old May 11, 2023 | 01:08 PM
Snarla's Avatar
Mercedes e350 coupe
You are fabulous!
Drinks anytime!!
Old Jul 24, 2023 | 11:56 AM
Snarla's Avatar
Mercedes e350 coupe
greetings from the swamps.
the issue with my non-working passenger side power seat door controls was a simple repair. A connection had come loose (maybe near the door hinge?). I didn't realize that the window and lock were non functioning , also.
The repair took 12 minutes..no charge ( except tip).
A happy ending.
Best,
Mark
