Front right tire air leak from the rim - fixable?
He suggested to get a new rim. I am wondering if anybody ever encountered the same issue? Can this be fixed or a new rim is needed. Its the original 17" rim.
Thx.
crack is bad and I would replace.
Have them remove tire from wheel and have it inspected by a WELD inspector as they have a little Ultrasonic tester which can check for cracks.
couple of hundred bucks for him..
or go to Car-Part.com--Used Auto Parts Market
and find a USED wheel from some junkyard in the USA.
or is a pin hole fixable?
Heck wont cost much and maybe worth it.....
I would try...
Duct Tape! nah... some sort of... Maybe 2 part Epoxy?
Maybe metal tape?
FLEX SEAL??
ooooo Door window flashing that 1/16" thick black super duper sticky stuff....
just clip a little piece and cover pin hole and use roller to roll edges...
Typar 4 in. x 75 ft. Butyl Rubber Copolmer Window and Door Flashing Roll BUTYL-001 - The Home Depot
A welding shop will do it for $200 including balancing the wheel. is it safe?
Junk yard grade B $350, tire shop said only cosmetic damage not structure?
New from dealer $533+$150core which is refundable if old core returned. Best choice and most expensive.
I like the idea of FLEX SEAL - clean it up real good rubbing alcohol as last step and then stick a flex seal patch over crack.
Save up for the new MB wheel as that is good price for any part from Dealer...
That Flex Tape looks interesting but it's expensive so I've yet to try it. I'm suspicious about it lasting. Maybe if it were in a place I could keep an eye on it, but I wouldn't feel comfortable if I couldn't see it. Plus, air would no doubt get under it, at pressure, then when you vent the air to change the tire it would push the tape off. At least that's how my brain see's it.
I've used it to assemble engines and do all kinds of redneck things and fixes.
I'd go with clear in this case. I'd clean the offending area with alcohol, and be sure you dry it or use compressed air on it, then rub the silicone stuff into the spot real good to get it into the hole. Plus I'd leave a thin layer over the general area. You can put pressure on it right away, if you really need to, but best to let it dry over night first.
