visual brake inspection please.
I am not mechanically inclined but I am trying to learn as I go with the 550. So, please be gentle.
So long story short, I was told a while ago that I would need to do some of the brakes soon. And well soon passed by, and I started hearing some brake noise. For some reason, it was in my head that it was the front brakes. They looked ok to me, so I felt no urgency... I went and took a look and I messed up.
Front Driverside. Is OK, no?
Rear Driverside, uh-oh. looks like nothing left and now need rotor replaced too. Feeling not so smart.
Front Passengerside, looks OK.
Rear Passengerside, looks to be on the brink of death, but caught in time to save the rotor.
Am I right in my assessment?
Fronts are OK.
Rear driverside is wrecked, needing rotor and pad replacement.
Rear passengerside, needs new pad.
Saddened that my lack of awareness has caused those gouges in the rear driverside rotor.
Probably <$500. Installed add ~$250
MB dealer will charge $$$$$ for the full set with pads
Also, if replacing one rotor…replace both
Can you remove wheel and look at caliper back side opening where sensor is on pad so you can see how much pad exists between the pad surface and the hole edge to that side?
That is where you measure pad life because once it breaks thru the sensro hole the sensor hits rotor and sets off dash light.
I'm on the fence about DIYing this, my skills are limited and so is my free time.
I'm in Canada and so far I've found powerstop Z23 at $410cdn for rears only. I'm on a budget so might have to stick with what the shop has, $325 for OEM/equivilent (smooth rotor).
Good point, I will replace rotors in a set. And will try to peek at the inside side of the fronts to check for wear, for the rears the outsides are visibly worn so no need to bother checking insides there.
No pad sensor light on dash... is that a standard feature? I have a 2010 E550 coupe.
And... should the wear and the rotor not be flat and uniform? On the front rotors, right after the drilled vents (you can notice more on the photo of the front passenger side) the outer inch or so the wear slopes inwards to the lip.
Are there competent independent MB specialists near you on Vancouver Island or nearby in Vancouver?
RE parts -----Here are some options for you on www.RockAuto,com.today.. They should ship to Canada ....not sure of the current $CN to $USD exchange rate
POWER STOP KOE6207 Stock Replacement; Includes Rotors, Ceramic Pads & Hardware Info
Front; 2-Door Coupe $168 USD
POWER STOP K5626 Z23 Evolution Sport; Includes Drilled & Slotted Rotors, Carbon-Fiber Ceramic Pads & Hardware (Instant $35 Off Manufacturer Rebate!)
Info
Rear; 2-Door Coupe $ 252.79 USD
POWER STOP CRK6207 Evolution Geomet Coated Kit Info
Front; 2-Door Coupe $247.79 USD
Amazon----Power stop Z23 Evolution Sport brake pads Front 2010 E550 2 door coupe $79 USD...
If doing it yourself, i would read up on how to or check Youtube for videos /procedure before committing. Be sure to check to see if car has electronic parking brake that may need putting into service mode before starting on rears. Be good to get a list of tools for the job so you know what you'll need to purchase too.
Do you have Harbor Freight in VC for tools? What about Canadian Tire ? Are they local to you to do the install?
CTC also has service locations in Victoria BC on the island and they do loan a tools too
And I'm not going to attempt this DIY, I'll take it to the shop. Just looking for better value parts for the money now.
As for measuring the lip on the front rotors, it's visually apparent and my guesstimate was by touch.
I've illustrated in the rotor pic. Hope it makes sense. The short edge of the triangle shows the lip. The right line shows the uneven wear, it tapers down from near the drilled vent to the bottom of the lip.
You are gonna end up ~$1000 with the parts i specc'd out and install labour , but if you take it to Mercedes Benz that will be $3000.
YMMV
let us know what u ordered and what the final total with install was.
You will like the improvement in stopping and the looks of the rust free rotors for sure :-)
considering these combos:
Rockauto:
POWER STOP CRK6207 Evolution Geomet Coated Kit Front drilled
POWER STOP CRK5626 Evolution Geomet Coated Kit Rear smooth
about $800 cdn shipped
FCP Euro:
Mercedes Brake Disc - Zimmermann 000421151207 Front drilled
Mercedes Brake Kit - Akebono 0004231212 Rear kit smooth
Mercedes Brake Pad Set - Akebono 0074206020 Akebono pads
about $900 cdn shipped
any feedback on these brands/combos?
https://germanparts.ca/
just under $900 cdn
has local pick-up options, quick shipping, and won't need to deal with possible extra duties of ordering from the States.
GL!
GL!
I've always used EBC pads with my E-class, I swear by them. Brake components is NOT an area to compromise...
I just bought a complete set f&r of Z23
The hard part is finding the motovation to do it.
@w205c43pfl you are right in that the rears do engage first, usually you can feel that in very light braking that is what 90 % of what cars do these days in heavy traffic. If you modulate with slightly harder braking, you can then feel the point where the fronts get activated. Jamming them on gets the fronts working very obviously. Try it in an empty parking lot sometime.
Brakes have been designed like that for decades with proportioning valves and smaller rear brakes. The smaller rears activate first then the larger front brakes take hold due to the fluid now being directed to the fronts
If you arent feeling much from the fronts then check for sticky front pistons on the E350/e550 series
