overfilled oil
Old Aug 29, 2024 | 10:42 AM
hacketta's Avatar
2011 C207 E350 cabriolet
overfilled oil
I realized that the dealer overfilled my oil (M272) by about 2 quarts roughly 2,500 miles later. I’ve extracted the excess, and I have three questions:
1. Is there an electronic overfill/ underfill warning in this car? I know that it doesn’t have a mechanism for checking the oil electronically.
2. Has this likely caused damage to the engine/ is there any way to tell? Everything has seemed to run fine, and I didn’t notice any bubbling/ foam on the dipstick before removing the excess oil. How much leeway does the M272 have?
3. I notice the oil level is significantly higher after letting it cool for several hours, is this the level I should be considering? (Instead of five minutes after shutdown as the manual suggests)
Old Aug 29, 2024 | 12:32 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Wow----Dealer? I would call a lawyer....they will of course claim you must have added the +2qt.
Old Aug 29, 2024 | 02:30 PM
W205C43PFL's Avatar
Sorry to hear that, sadly dealership overfilling is more common than you think, been there before : (
Old Aug 29, 2024 | 11:02 PM
hacketta's Avatar
I think I know what happened: they must have checked the level immediately after turning the car off for five minutes and made sure the level was near the max. After removing two quarts and being off for only five minutes, the level is at the bottom of the range. When the car sits over night, this is towards the top of the range.
I know the manual says that you can check the level after the car has been off for only five minutes, but it seems that this is likely not enough time (at least to fill to max)?
Old Aug 30, 2024 | 08:12 AM
W205C43PFL's Avatar
Well, the fresh oil is not warm from the box, as a result, cold oil requires at least 30 minutes of shutting off to let it drain back down on most MBs.
Old Aug 30, 2024 | 01:25 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I dunno how people screws up oil change. It is very simple. Drain the oil and look at how much oil was taken out then check the manual to see the engine's oil capacity then if it evens out refill the same amount. If the oil you took out is same as what the manual states, no need to guess work and do the wait for X minutes thing.
Old Aug 30, 2024 | 01:49 PM
You are discounting common core math, public schools and DEI.......
Old Aug 30, 2024 | 02:10 PM
hacketta's Avatar
Would an oil examination service like Blackstone likely be able to detect internal damage from this? RPMs were kept low during this period, so I have my fingers crossed it’s okay.
Old Aug 30, 2024 | 03:28 PM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
The dealer where I used to have my maintenance done routinely overfilled my engine oil. When I complained about it, they said the fill amount is dispensed automatically based on the VIN for the car. To this I replied, "Then you're not completely draining the old oil."
Old Aug 30, 2024 | 05:30 PM
W205C43PFL's Avatar
Yes, it is correct that the machine will automatically calculate the oil that is correct for the vehicle, you assumption that they did not completely draining the old oil/or suction out from dipstick for vehicles with a dipstick is also correct, it is a common occurrence from experience.
Old Sep 9, 2024 | 11:04 PM
hacketta's Avatar
Now that I’ve gotten the oil within the range on the dipstick (top half when cold and bottom half after being off for five minutes) the “check oil at next refueling” light comes on… Is this sensor likely broken? It never warned me of the oil being too high, and I don’t imagine the dipstick could be misleading 🙃
Old Sep 9, 2024 | 11:16 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
High oil quantity is not terribly destructive. It will cause higher than normal pressures. If the pressure is long enough or powerful enough, if will look for the weakest part of the engine to leak out. Look for oil leaks, especially around seals, breathers, and dipstick, if you have one.
