E53 Snow Tires
I have looked at a few tire web sites and can't find the the MO Pilot Alipin 5s or the MOE Sottozero 3s.
(MO = Mercedes OEM approved/custom part, MOE = Mercedes OEM Extended mobility [run flat] custom part.)
I expect this could change in the near future.
The staggered set is also listed for the 2018 E43 Sedan.
I expect to use the staggered set on my E53 when they release it from Baltimore.
*** Warning *** I was wrong. These DO NOT FIT the E53.
These wheels have too much offset and interfere with the suspension arms.
The rumor is that the standard 4Matic starts at a 50:50 torque split, but the E43/E53 AMG 4Matic+ is rear biased.
This could cause faster rear tire wear.
Because the tires are unidirectional, the assembly is corner specific and cannot be rotate.
T
The following should also work, but they are not listed for the E43.
They are also unidirectional, but could be rotated front to rear.
I expect that the could be tail happy with the E43/E53 4Matic+
First:
Get a set of staggered 19" wheels for your E53. The wheels for the other Es will probably NOT fit.
You will also need the pressure / temperature senders and center caps.
Option 1 Runflats: (This is what I have and what I think Mercedes wants.)
Pirelli Winter Sottozero 3 Run Flat marked MOE (Mercedes Oem Extended run)
Front 245-40R19, Rear 275-35R19, V speed, XL Xtra Load.
Option 2: Conventional snow tires and...
Michelin Pilot Alpin 5 (PA5?) may be marked MO (Mercedes Oem)
An air compressor, hose, and can of fix a flat. (These fit in an indentation under the trunk floor.)
The tires are now readily available from Mercedes parts, Tire Rack and other tire stores.
The wheels, air compressor, and fix a flat are available from Mercedes parts.
The Pirelli run flats steering feel is only fair (rubbery), but you can drive to a Mercede dealer after you stick a piece of steel through the sidewall.
I would expect the Michelins to have better performance and steering feel.
I have only used the air compressor to fill my sisters exercise ball.
Hope this helps.
Thanks!
