Lowering an E53
1. You can lower it switching just suspension to sport mode. I do this for mine. I configured individual mode with all in comfort except suspension, it is set to sport.
2. You can get a lowering module like this
http://loweringmodule.com/lomo-obd-s...ion-module-t1/
As for me I go with first option
Thank you for the reply- I do not own the car yet- how is the Sport suspension setting on a daily basis? And about how much lower is it?
If im correct the sport is lower by an inch or less, but not more
Here is mine lowered with Sport mode
I dont mind a bit tighter - My wife has an M2 for whenever I want to lose my fillings...
You will be ok anyway
E coupe with airmatic not so comfy like S class but still. I love it
Yes I love the S but the E does both luxury and Sport- the S does luxury perfectly but just too heavy at 4800 lbs. for any back roads driving. While the S isn't perfect- I dont want to go with a C63S just too amped up - the E looks perfect and will AGE VERY WELL. Will look good now and 10 years from now.
I am buying the Designo seat option as I have been told they are a bit more comfy than the standard sport seats- that I find pretty hard actually. And the gas mileage boost is nice too. Thanks for the help! Your car is awesome.
If they are classy E53 five double spoke AMG wheels than you will be not enough with 10mm in the rear
Mine on the photo has 13mm in the rear and Im thinking of adding more especially when suspension is in sport mode
And 13mm is the thinest you can add because of the hub
@FedM Do you mind sharing what brand spacers and the size you are running on your E53? I just purchased a 2021 e53 coupe and first thing Id like to add are spacers.
It looks like keeping the car in sport + will lower the car, so maybe I do not need lowering links?
Does sport plus setting keep the car lowered OR only while moving?
5 buttons including start button every time I start the car.
Again, keep in mind my rear tires are a little wider than stock, and the rear look is just perfect. Front with my stock 245 width tires now i would go with 25mm spacer easy. But plans are to change the rims too on the next tire replacement, will go 20 or 21 rims, and wider tires, not sure the size yet.
Via OBD module. Plug-and-play. 1 min installation process.
No wires, no soldering, no laptop, no schedule.
Visit mwmods.com
Package deals for forum members.
