Memory full error!
Basically doesn’t sync your contacts if you have a large address book.
Search owners and/or COMAND manual for "contacts" here:https://www.mbusa.com/en/owners/manuals
It indeed has a maximum. If you first let it sync, until the error appears, and then disable syncing, you at least have the max (5.000?) contacts and no more errors after it.
On Android there is a BT Phonebook app, that makes it possible to sync only certain contacts (categories, etc), so you can label the most important (5.000.....) ones.
Damn some of you are really busy/popular people to have more than 5000 contacts in your phones. I have got maybe 300 and I thought that was a lot and I likely don't regularly/ever speak to majority of them.
2018 e400 manual extract:
Looks to be only 3,000 for this COMAND version if you don't import I presume.
Contacts
Information about the contacts menu
The contacts menu contains all contacts from
existing data sources, for example mobile phone
or memory card.
It is possible to store up to 6,000 contacts:
or memory card.
- 3,000 entries are for permanently saved contacts.
- 3,000 for contacts loaded from the mobile phone
