USB Port for Carplay or Andriod
It seems that this USB port does not turn off itself after the engine turned off more than 15 minutes.
My vehicle is a 2019 C238.
I called a few dealerships and they did not aware the discharge.
That’s why I asked in this forum, members here know more than the dealerships. 😁
Got in car and plugged in the phone, it started charging.
Started the car - obviously still charging.
Turned off the car, still charging.
Opened and closed the door (which turns off radio, garage door buttons, etc) and the phone kept charging.
So this tells me unless there's something activating it when the key is in the car, it's on all the time. I do question why this is a big deal. If the car battery charges up your phone, it shouldn't run it down unless it sits in there for quite a long time using the car battery to keep it constantly topped up. Like days or over a week. If you accidentally left your phone in overnight and it runs your battery down, it's time to check the battery or alternator. Is there a problem you're trying to solve?
I was adding an aftermarket dongle (carlinkit) and attached to the USB port in order to make it wireless (obviously, it works).
However, the problem was this USB phone port was always "ON", as a result, the carlinkit could not turn off.
So, every time when I left the car, I have to unplug the carlinkit in order to prevent the battery drain.
If you use carlinkit wireless adapter, our dongle will automatically disconnect after you lock the car and the key is 10 meters away from the car. Please do not worry.
Btw, if anyone has interest in our products, you are welcome to take an 18% discount code for your action. It is specially for the MBWorld Forum members.
Recently, our store has released a new arrival--carlinkit T2C. It can upgrade the Tesla (Model X/ Y/ S/ 3) for wireless carplay, if your family or friends need it, you are welcome to share the info to them.
https://carlinkitcarplay.com/product...arplay-adapter
