E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Battery
Old Apr 24, 2023 | 11:31 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Question Battery
Whats everyone doing about getting a battery? Theres gotta be a cheaper option than $1800.
Links?
John
Old Apr 26, 2023 | 06:30 PM
unlukky's Avatar
Hello? Testing testing, 1,2,3,4.
John
Old Apr 27, 2023 | 12:35 AM
konigstiger's Avatar
'71 Pinto
Shop 0019828108.
File Type: pdf
Old Apr 27, 2023 | 02:29 AM
unlukky's Avatar
Thank you, sir. Thats a little more reasonable of a price.
John
Old Apr 27, 2023 | 05:45 AM
ygmn's Avatar
2015 E400 Sedan
Auto zone or Wal Mart
Old Apr 27, 2023 | 08:24 PM
unlukky's Avatar
Autozone doesnt even pull up a battery when my year, make, and model are plugged in.
John
Old Apr 28, 2023 | 11:33 AM
The_Judge's Avatar
2018 E400 Coupe
Try Googling "battery for 2019 mercedes benz e450" and you'll find a lot of places that do carry the battery for your car.
Old Apr 30, 2023 | 07:57 PM
W205C43PFL's Avatar
John
Guess also try costco
Old May 2, 2023 | 12:14 AM
unlukky's Avatar
For the record guys. I did know the part number and did search it online. They are either not in stock or no shipping.
This is why I asked in the first place.
Thanks, John
Old May 3, 2023 | 06:44 PM
W205C43PFL's Avatar
Thanks, John
Yup we understand that is why we suggested third party replacements.
Old May 3, 2023 | 06:56 PM
unlukky's Avatar
When I call them, my car isnt listed in their data base to cross reference.
John
Old May 3, 2023 | 07:21 PM
W205C43PFL's Avatar
John
Even costco?
Old May 4, 2023 | 04:58 AM
unlukky's Avatar
Even costco?
Yes, even Costco. The drop down menu does not include my car.
John
Old May 4, 2023 | 09:37 AM
W205C43PFL's Avatar
John
Is it just your model year that isn't there?
Old May 4, 2023 | 09:42 AM
teksurv's Avatar
2024 EQE 500
Look for a 2018 E400 (same engine) or even E43AMG. I think it's lazy filtering on the vendor's part. I checked Costco, which sent me to Interstate batteries.
Old May 4, 2023 | 09:43 AM
W205C43PFL's Avatar
Good advice I think they are identical spec batteries.
Old May 4, 2023 | 09:22 PM
unlukky's Avatar
That worked out for me. Ill do that. Thanks, ya'll.
John
Old May 9, 2023 | 04:41 PM
W205C43PFL's Avatar
John
Good to hear thanks for updating us.
Old May 21, 2023 | 01:30 AM
mickhoog's Avatar
W213 Night Edition 220d. (ML250 SLK350AMG)
I purchased a Varta F21 Silver Dynamic battery. It's the same as the OEM one.
I had it installed and it was just plug and play
Before the battery swap my start stop stopped working. It's working now.
I have an E220d 2017
Old May 23, 2023 | 10:25 AM
W205C43PFL's Avatar
Thanks for sharing your experience with other batteries.
Old Dec 8, 2023 | 02:25 AM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Did the new battery require to program / register after installed?
Old Dec 8, 2023 | 11:38 AM
giannatj's Avatar
2018 E400 Coupe, 2021 Cadillac XT5
I may be missing something but I sense you guys are overthinking this. I bought a Duracell at Batteries plus. They plug some kind of electronic device under the dash to retain everything while they're doing the install and the car doesn't even know anything is happening. They dropped the new battery in and the eco shutoff starting working again. It had stopped before and I took that as my sign that it was time for a new battery on the 60 month old car.
Old Dec 8, 2023 | 04:07 PM
Ultraman's Avatar
Oh, you mean something like a battery charger (12v) to connect the positive and negative wires under the hood prior to replacing the battery.
Did the new battery has the same amp as the original one?
I am thinking getting a new one from either Costco (if they have one) or the Interstate from the autoparts store.
Old Dec 8, 2023 | 07:29 PM
giannatj's Avatar
It looked just like the portable batteries that they use to do emergency jump starts except without the cables and alligator clips. It had a cable and adaptor that they plugged in somewhere under the steering wheel. I imagine it just maintained power to the components while the battery was disconnected. Everything worked normally afterward, all the radio presets, seat memory, etc. were the same. Any shop that installs batteries professionally should have one. The install was simple except that they needed a 10" extension on their socket wrench to loosen and tighten the tie downs. I don't have one of those so I wouldn't try it myself even if maintaining power wasn't an issue.
The battery was the same dimensions and the rated CCA Amps were higher than the OEM battery. I'm sure Costco has something compatible. I just used my local Batteries plus store because they were convenient and I had received good service from them previously. I think the list price on the battery was $260 and I got a 10% discount.
Old Dec 9, 2023 | 01:12 AM
Ultraman's Avatar
Oh I see, thanks for letting me know.
