E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Spare Tire Question
Old Aug 7, 2023 | 08:19 PM
RNajarian's Avatar
Veteran: Air Force
2020 E 350; 2022 E450 Coupe; 2005 Porsche Cayenne; 1975 Porsche 911 Carrera 3.0
Spare Tire Question
Both my 2020 E350 and 2022 E450 have run flats. For piece of mind I bought (what was advertised to be) a spare tire for a 2018-2020 E Class as insurance during a long road trip.
The tire/rim are in fantastic condition but the concern is the tire is from an Audi Q5. The bolt patterns for Audi Q5s are the same as an E Class, 5 x 112.
Does anyone know of any issues using this spare on my cars? The diameter is 19” so though it is a doughnut spare, it is obviously larger than the typical 17” spare.
Thanks for your insight
Old Aug 8, 2023 | 03:07 PM
RNajarian's Avatar
Veteran: Air Force
BAD News #1
I took the tire to my tire shop for my answer. The bolt pattern is correct but my coupe has larger calipers and the rim does not fit.
Bad news #2
One of the run flats has a bubble and needs to be replaced. I’m looking at $400 for the tire, ground shipping plus installation. Likely $500 after everything is said and done.
I’m going to research how I can install normal tires.
Not Happy
Old Aug 8, 2023 | 04:34 PM
BillMFD3's Avatar
E450 Coupe
I got the modern spare for my 22 coupe
id recommend it
Old Aug 8, 2023 | 04:49 PM
RNajarian's Avatar
Veteran: Air Force
id recommend it
Like an idiot I thought I would save a buck and buy a used spare. I have heard nothing but positive things about Modern Spare.
That’s my next purchase
Old Aug 8, 2023 | 05:20 PM
BillMFD3's Avatar
E450 Coupe
Here’s the spare and weathertec trunk liner
Old Aug 9, 2023 | 12:55 PM
RNajarian's Avatar
Veteran: Air Force
Well it looks like I will be able to return the tire - phew.
Bill regarding the Modern Spare you bought. Did the “regular” one for the E450 Coupe fit your wheel? Did the caliber get in the way?
OR did you buy the tire for the AMG E 53 vehicle which made accommodations for the larger caliber.
Would you mind posting photos of your caliber?
EDIT: I called the Modern Spare Company (Disclaimer: I have no financial (or ANY) relationship with the company) and ordered a spare/jack/carrying bag combo.
Thanks everyone for your help
Old Aug 9, 2023 | 07:15 PM
BillMFD3's Avatar
E450 Coupe
Never tried it on, maybe I’ll give it a go over the weekend and report back
here’s the front caliper pictures
Old Aug 9, 2023 | 07:45 PM
RNajarian's Avatar
Veteran: Air Force
If the Modern Spare tire doesn’t fit they have a spacer to push the rim/tire away from the caliber. That’s what they do for the AMG cars
Old Aug 10, 2023 | 07:44 AM
BillMFD3's Avatar
E450 Coupe
May want to pick these up tooAmazon.com: CRAFTSMAN CMMT98282 CRFT 3 PC NON-MARRING LUG NUT SET : Tools & Home Improvement
Amazon.com: WHEEL CONNECT Wheel Alignment Pin, M14X1.5 Wheel Hanger, Rim Stud Pilot Pin,Guide Studs. Tool for Changing Tires on Cars with Lug Bolts. Made of Stainless Steel.Metric 14 x 1.50. : Automotive
Old Aug 10, 2023 | 12:59 PM
MBGuy2022's Avatar
2019 S560 4MATIC Sedan
https://ezsparewheel.com/
Try this website for a spare tire.
Old Aug 10, 2023 | 08:57 PM
RNajarian's Avatar
Veteran: Air Force
Bill I checked the WeatherTech website. They say the mat you have does NOT fit vehicles equipped with Burmester® High-End 3D Surround Sound System. Does your car have that sound system?
Old Aug 10, 2023 | 09:17 PM
BillMFD3's Avatar
E450 Coupe
I have the Bermiester Sound System that came standard on the car, not the 3D. I had the same question. The liner fits fine.
I did have to cut the small slits so the tie down hooks could be used.
Old Aug 10, 2023 | 11:08 PM
RNajarian's Avatar
Veteran: Air Force
Thanks for the reply. I’ve got the Burmeister, not sure about the 3D, which probably means that I don’t have it.
Thanks for your help.
Old Aug 11, 2023 | 05:25 AM
BillMFD3's Avatar
E450 Coupe
From my window sticker
