E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Transmission Fluid and Filter Procedure
Old Mar 3, 2024 | 04:14 PM
Grant_J's Avatar
'18 E400 Cab
Hi all, I'm coming into my 60,000 mile service and see a need for transmission fluid and filter replacement. 2018 A238 (USA). Anyone have a procedure for this or part numbers? Recommendations for success? I haven't done this one and considering taking it to a shop, but would really like to learn. On the maintenance list it says AP27.00-P-2702B if that helps.
Thanks,
Grant
Old Mar 22, 2024 | 01:15 AM
Grant_J's Avatar
'18 E400 Cab
Hi everyone,
It was weird getting no response on this at all, but I had to move forward with a couple of great youtube videos from Sprinter Zone and Project Athos. Different cars, same transmission. Anyway, I broke a small bolt that holds the transmission pan in place ( 1 of about 8) and will need to tap and replace it. Anyone know a part number for this tiny bolt? It's an 8mm E-Torx. For anyone interested, here's a picture of the broken bolt and my garage when almost finished with this 60k service. Fun day!
-Grant
Old Mar 22, 2024 | 10:46 AM
MBGuy2022's Avatar
2019 S560 4MATIC Sedan
Miss this forum.
You remind me of myself by the pictures. I love DIY!
I can't believe you haven't purchased the WIS/ASRA with EPC (Electronic Parts Catalogue) on USB or download. It's the complete parts catalogue with Service Manuals. (parts catalogue only up to build date 6/2018 by vin). It's cheap on eBay.
The Transmission/Transfer case service is my last DIY project on my 2019 S560 to complete the 60K service. I would have to buy the adapters and pressure tank but that's OK. Still cheaper than the Mercedes dealer.
Did you drain the torque converter by its drain plug? I have to buy a new drain plug for that before starting the procedure on mine.
Your broken bolt is part # A0029909503 and you need 10 for the oil pan.
Your torque converter drain plug is part # A0019901117.
This is of course if I looked it up right. I do not have your vin.
Old Mar 22, 2024 | 11:06 AM
Grant_J's Avatar
'18 E400 Cab
Thanks MBGuy! How is this the first time I've seen that you can even download the EPC?!? I'm all over that. For the torque converter, I saw mixed reviews on whether to drain/replace that fluid or just the 5L in the transmission and overwhelmingly seemed just the 5L in the transmission was the answer, so I didn't drain the torque converter. Nobody responded to my request above for the procedure, so doing with what I could find online. If this manual says to do something different I may go do it again. Hopefully not...the fluid isn't cheap.
Old Mar 22, 2024 | 11:52 AM
MBGuy2022's Avatar
Found this on eBay. It doesn't expire and includes everything I mentioned. If you contact the seller and ask for the download instead he can work that out with you I believe.
https://www.ebay.com/itm/38384247126...Bk9SR4CBxe3MYw
Old Mar 22, 2024 | 01:19 PM
Grant_J's Avatar
'18 E400 Cab
Thank you sir! I'm a little leery of the mixed feedback on that seller but see several options there. Will purchase for sure. Still shaking my head that I didn't realize it before.
Old Mar 22, 2024 | 02:52 PM
MBGuy2022's Avatar
Here are some question about the transmission service to you.
In my transmission service procedure draining the torque converter is part of it. If you don't do it do you end up overfilling the transmission fluid if you fill it to the top of the overflow tube?
Another way to look at it. If you drain off 5 quarts but it takes 9 quarts to fill it where the tube starts to overflow.
Did that occur? Did you have to re-drain or add fluid after cranking it up?
I would really like to know how that drain tube and drain plug work with all their various positions.
Did you buy the tool to turn things with?
I read the service procedure but without those items in hand it's hard to figure out how they move in your head.
Old Mar 22, 2024 | 03:09 PM
Grant_J's Avatar
'18 E400 Cab
@MBGuy2022 Yes, I bought the drain tools and pneumatic pump (which both worked fantastically!). Here's what I experienced, which matched the videos I saw:
1. While engine is cold, unplugged the drain plug in transmission pan, a little fluid came out (less than .5L).
2. Inserted the special key tube tool, (Starts in position 1 as labeled on the oil pan) and turn to position 4. The tranny oil all comes out of the tube. I had to hold it or the key would just fall out which made a mess.
3. Turned back to position 1.
4. Removed oil pan, cleaned the area where the gasket meets the metal with brake cleaner.
5. Put in the connectors and pumped in 5L of transmission fluid, turned off the valve to cut off pressure, left the pump tube connected to the car and pump.
6. Started the car and let Engine warm up. (HOLD THE BRAKE!), then ran through 3 cycles of 10 sec on R, 10 on N, 10 on D, 10 on P, repeat. Leave car running.
7. Placed catch pan under tranny pan, and removed the tools/tube from pan. A little falls out (that's the extra).
8. Re-place oil pan plug.
9. Shut off engine.
Positions 2 and 3 seem to just slow down the flow of oil, I couldn't find that they actually did anything useful past that. I saw in one video they also experienced that position 2 which 'should' stop draining when excess is all out, just drains all the oil out.
Here are the useful youtube videos I could find:
Old Mar 22, 2024 | 04:05 PM
MBGuy2022's Avatar
Found this for position descriptions.
Old Apr 19, 2024 | 05:08 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
pump in 5L of fluid and you will be fine, because these 725 trans have twin filters, the fluid doesnt get as dirty as the old 722 boxes. Not draining the T/C is ok.
i have done the service half a dozen times w/zero issues. we have E400 and E450 with the same trans. Love the C238 body style, the new CLE's don't look as nice to me, they look more like a C-class coupe! oops just realized this thread is 2 years old!!
Old Apr 20, 2024 | 02:15 PM
Grant_J's Avatar
'18 E400 Cab
Thanks @Redwood415 . Yeah turns out that procedure worked. So far she's driving great.
