Door Seals
My door seals need to be replaced on my W123 (1981 240D 4speed). Just bought it second-hand in Southern California - 344k, everything (except for the sunroof) works. A daily driver, not concours.
Anyhow, I found some relatively inexpensive custom-fit seals online, but I need to know what is involved in replacing them. Relatively new to the DIY crowd, but I think that this is something that I can handle with some patience and time.
Your help would be greatly appreciated.
Gary
Ensure that you remove all of the housing brackets; the front doors have a small bent metal frame inside the hinge side. Take time to work the bottom edge, and be sure to glue and place the lower section in the track.
It is not a hard job, and one that will only make you realize...that you now need to change the window felts and trim...
Good luck! You can do it!
I replaced mine when the doors were off...Hence...My experience...If you can easily detach the stop check, and loom the seal into that area...Go that path.
I apologize if my post was a little misleading...
Thanks 240D 3.0T!
However, glue was also mentioned. I've read elsewhere that they need to be threaded, not glued. Is glue necessary? Are the original ones glued in? That may change my approach.
Gary.
Did not remove the doors, but did unclip the door checks (replaced the front ones with aftermarket units - no big deal)...
All and all, not a tough job.
Also, I'm wondering how to put in the hard-to-fit parts. I heard someone mention soapy water, but how can I use glue at the same time? Is contact cement right?
Finally, I can go back and get some other stuff (except for one window which is closed and cannot be opened) to seal my car. Which seals need to be replaced to help get rid of the whistling noise at high speed?
Thanks a lot!
