E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Engine swap, transmission?
Old Aug 2, 2010 | 07:36 PM
XLR8R22's Avatar
'78 300D, more to come soon!
I'm thinking of swapping my 300D motor with the turbo engine from a 300SD. The high altitude and hills where I live are a killer, especially in traffic. First off, will the engine fit? Is there anything I would need to do? Or will it just bolt right in and hook up? Also, are the transmissions different between the two models? I've been looking for specs, and as far as I can tell they are the same transmission, but just want to make sure. I know the rear end gears are different, but is that it?
Old Aug 4, 2010 | 07:57 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Its a direct swap. The non-turbo transmission can't handle the higher power.
Old Aug 6, 2010 | 06:44 AM
XLR8R22's Avatar
So I would need the transmission, too? Do you know if they are any different other than being more heavy duty? Different gear ratios?
