E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
need help with 1998 E300D fuel leak repair
Old Jan 15, 2011 | 09:04 PM
dieselbgood's Avatar
1998 E 300 D
I have a 1998 E 300 D. I smelled fuel inside, and looked under the hood. There was fuel dripping from under the intake manifold cover on passenger side, above the exhaust manifold. Can anyone tell me how to do this repair ? I think it's o rings and lines. I think I can do it with some diagrams, and instructions. Am I correct ?
Old Jan 15, 2011 | 09:31 PM
Outre's Avatar
83, 300D Federal
Your description is not specific enough to give any repair Instructions.
You need to remove enough from the Engine to see exactly where it is leaking.
Old Jan 16, 2011 | 09:28 AM
1998 E 300 D
Thanks for your help, I will remove the cover on the intake manifold.
Old Jan 16, 2011 | 12:17 PM
ohlord's Avatar
First
wrong section for your car
W210 forum
next ask in the w210 forum on www.benzworld.org
they have a diy on o=rings etc. there.
Also the diesel section on www.peachparts.com
http://www.peachparts.com/Wikka/OM606DeliveryValveSeals
When done
don't crank like crazy to prime
Hold a well rung out rag in the fuel tank opening and use it as a gasket around an air nozzle from an air compressor. Inject a bit of air to pressurize the fuel tank while someone cranks the engine till started.
Old Jan 16, 2011 | 12:19 PM
1998 E 300 D
Oops ! Thank you very much
