Wiring Harness Woes
Automotive Recalls and Technical Service Bulletins for 1993 Mercedes
Benz 300CE (124 Chassis) L6-3199cc 3.2L DOHC (104).
Provided by ALLDATA
Bulletins for 1993 Mercedes Benz 300CE (124 Chassis) L6-3199cc 3.2L DOHC (104)
Safety Recalls
TSB Number Issue Date TSB Title
1. 96V175000 SEP 96 Recall 96V175000: Headlamp Washer Pump Replacement
2. 95-0223 MAR 95 Recall - Wiring Harness Chafing/Shorting
3. 95V031000 FEB 95 Recall 95V031000: Wire Harness Protecter Installation
Definitely go with the recall route and try a different dealer....or DIY...its easy to install....lay the new one next the the one plugged in and go crazy. Took me only about 1.5 hours on my 500E.
I haven't heard of anybody in the past two years post of having their engine wiring harness replaced under dealer goodwill policy. These cars are now too old for MB dealers to concern themselves with this problem.
Recall No. Date issued Title
CMP95_0131 JAN 95 Campaign - EGR Valve Replacement
77_011A APR 95 Campaign - Replacing Soft Top Bow Actuating Levers
I'm not sure if they've been done.
You should also check the small three wire harness that goes to the oil pressure sender, oil level sender and starter. This harness is near the drivers wiper arm. These wires are not included in the harness and are not available. The wire end can be bought and it only took me 1/2 hour to make the harness
